how on earth are you supposed to get the steering column bolts out when the heads have been snapped off?
damb steering column bolts
Tom Sanderson
, Mar 27 2006 10:12 AM
8 replies to this topic
Posted 27 March 2006 - 10:12 AM
Posted 27 March 2006 - 10:24 AM
angle grinder
file a flat in them and use a screwdriver
angle grinder
mole grips
oxy acetalene
angle grinder
mole grips
oxy acetalene
Make a slot with a chisel, and with a hammer and chisel follow it round to undo it.
Posted 27 March 2006 - 10:30 AM
you make it sound easy surely it can't be that simple
Posted 27 March 2006 - 11:09 AM
Drill
Take the coloumn out first.
Posted 27 March 2006 - 11:25 AM
all i used was mole grips on the head end.
Posted 27 March 2006 - 11:31 AM
centre punch the head, then use a 3mm drill to start, and an 8mm drill to take the head off. Takes 10 minutes.
Posted 27 March 2006 - 12:01 PM
same here (OK, maybe with different sized drills), but yeah, centre punch, drill pilot hole, then drill head off.
Posted 27 March 2006 - 12:19 PM
Make sure you're drilling the head, not the nut! The nut is then re-useable.
Buy new bolts in advance too, proper ones not some B&Q chocolate junk.
