Engine runs fine (carb'd 1380cc, recently tuned on a rolling road. Thanks Rob!), but I can't select any gears. If I put the stick to 2nd and turn over the ignition/starter there is no "jerk" (for want of a better word) so I assume there is no longer a connection between the block and the box.
When the engine is running and in gear there is a grinding noise coming from the engine/box as I let the clutch out, but no movement.
I don't have time until the weekend to pull the engine so I can't physically see the problem, but if anyone can suggest what to look for at least I'll have a head start come Friday.
I assume the simplest solution is to swap the entire box, and I have an old 998 in the shed, assuming both engines are a similar age is there any difference between a 998cc gearbox and that from a 1275 (which is what I think the engine was to start with). Or would I be better off getting a recon? Any suggestions who/where from in the Lancashire area?
(I'm searching atm but without any keywords other than gearbox is ****** I'm a bit lost)
Thanks!
Edited by somecrapname, 23 October 2012 - 11:17 AM.
