Cam Tolerances ( Sideways)
44 replies to this topic
#1 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
  • Local Club: Loan wolf
Posted 25 October 2012 - 03:42 PM
Anyone know what is the max sideways movement for you cam is? As a pre assembly check mine is 6 thou of inch and thats without he timing plate gasket on!
#2 ACDodd
ACDodd
  • Mini Docs
  • 2,832 posts
Posted 25 October 2012 - 03:48 PM
With the retaining plate and sprocket fitted and torqued, end float should be 0.003 to 0.007".
AC
#3 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 25 October 2012 - 04:54 PM
AC
Thanks for that. Any idea of the torque settings for oil pump and the retaining plate nuts. Cheers
#4 ACDodd
ACDodd
  • Mini Docs
  • 2,832 posts
Posted 25 October 2012 - 05:53 PM
Do you not have a haynes manual?
AC
#5 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 25 October 2012 - 05:56 PM
AC
why? don't you know?
#6 ACDodd
ACDodd
  • Mini Docs
  • 2,832 posts
Posted 25 October 2012 - 05:57 PM
8lbft for the later flange bolts.
AC
#7 ACDodd
ACDodd
  • Mini Docs
  • 2,832 posts
Posted 25 October 2012 - 05:58 PM
I would not expect that info to be asked on a forum as this info is available in just about every manual.
AC
#8 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 25 October 2012 - 06:56 PM
AC
Sorry. I would prefer to receive no answer than being asked if I had a Haynes manual. I would have thought most tech questions asked on the forum could be found else where, but isn't that the point of a forum? A fast, central, resource? Thanks anyway.
#9 ACDodd
ACDodd
  • Mini Docs
  • 2,832 posts
Posted 25 October 2012 - 07:04 PM
I disagree, forums are for those questions that cannot be found easily, or we would all be here answering questions relating to torque settings or plug gap setting to everyone.
AC
#10 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 25 October 2012 - 08:08 PM
AC
Oh well, at least it has encouraged me to dig out my old (held together by duck tape) bought in 1989 haynes manual. Here's a non hanyes available question for you. What if my end float is 0.36mm and the max should be 0.17mm with a new retaining plate?
#11 ACDodd
ACDodd
  • Mini Docs
  • 2,832 posts
Posted 25 October 2012 - 09:28 PM
Then you need to machine the cam sprocket to reduce the endfloat.
A competent machine shop will be able to do this for you.
AC
#12 Cooperman
  • 23,513 posts
Posted 25 October 2012 - 10:10 PM
One might wonder where that 0.015" has come from. Is the cam sprocket hard against the cam with lock washer and nut fitted? I've never seen that, even when the triangular cam plate has been a bit worn. Very odd.
#13 mini-luke
mini-luke
    Postman Pat
  • 2,362 posts
Posted 25 October 2012 - 10:15 PM
Asking AC the torque setting for something is like telling cooperman his arch gap is too big!
#14 ACDodd
ACDodd
  • Mini Docs
  • 2,832 posts
Posted 26 October 2012 - 08:22 AM
Its is actually very common when using aftermarket cam sprockets, about 75% I see need mods.
AC
#15 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 27 October 2012 - 04:58 PM
Ive just got the timing plate and triangle plate on and torqued. No cam sprocket on, what difference does having the sprocket on? Surely it just moves with the cam
