Hi there, I've got a mini with a R1 5PW and don't know how to fit the power commander as there is no plugs left after the loom was spliced into the mini loom ( done by the person I bought the project off ) How do I get it to fit without replacing the whole loom. Any help will be much appreciated.
R1 Mini Loom - Power Commander Fitting
r1minin00b
, Oct 26 2012 06:17 PM
6 replies to this topic
Posted 26 October 2012 - 06:17 PM
Posted 26 October 2012 - 10:05 PM
if its the same as mine theres a blank of ecu
Posted 27 October 2012 - 11:03 AM
what you mean a blanking plate that you can plug the pc3 into?
Posted 28 October 2012 - 12:25 PM
thought power commander was connected in-line? so you unplug a connection and it has mating plugs.. so you plug it into the system
Posted 29 October 2012 - 04:51 PM
That's what I thought, this loom doesn't have any plugs free Didn't know whether there was a way of splicing the pc3 in. I really don't want to have to do redo the whole loom
Posted 30 October 2012 - 02:38 PM
You're right it's just a piggyback device with four connectors. I think you would need to identify each wire on the R1 wiring diagram to be able to integrate the two successfully.
Posted 30 October 2012 - 03:42 PM
On a 5pw you basically disconnect ecu loom plug(6pin?) and plug either end into power commander
