Clubman Extra Lights In Grill?
25 replies to this topic
#1 josrey
josrey
  • 92 posts
Posted 30 October 2012 - 07:32 PM
Found this pic on here and there are extra lights set int othe grill can anyone tell me if its hard to to or how to do it?? 'because i would like to do it to my clubman.
Attached File  P1010997.jpg   91.73K   98 downloads
#2 1275GTS
1275GTS
  • 668 posts
  • Local Club: bmc
Posted 30 October 2012 - 07:39 PM
thats mine. Its a golf Mk2 grille cut down in length and rejoined. Quite simple really hardest part is rejoining it. I used some 2 part putty that i got from work and put some strips of sheet metal under the grille fins to strengthen it.
#3 dave-88_123
dave-88_123
  • 302 posts
  • Local Club: jurrasic coast minis
i belive that is a shortend mk2 golf grill i think it was the golf driver that had the extra lights
#4 josrey
josrey
  • 92 posts
Posted 30 October 2012 - 07:42 PM
Thanks mate it looks a hell of a lot nicer and contoured than having spots attached to a rail i might consider this :P so is it just standard headlights and then the mk2 grill with lights aswell??
#5 1275GTS
1275GTS
  • 668 posts
  • Local Club: bmc
Posted 30 October 2012 - 07:51 PM
yep, got mine for £35 with the spot lamps off ebay. The spot lamps work really well. Also I hid the join by using the original clubman/gt BL grille centre badge.
Edited by 1275GTS, 30 October 2012 - 08:01 PM.
#6 josrey
josrey
  • 92 posts
Posted 30 October 2012 - 08:15 PM
I noticed you had used that lol i think i would probably mold them together with fiberglass (as the grills plastic isnt it?) and then sand it and repaint black
#7 splintercat
splintercat
  • 616 posts
Posted 02 November 2012 - 12:09 AM
mate just seen this ......looks stonking....... just gotta let you know might have a go at this meself seen a few of these grills on flea bay... so your saying i buy a mk2 grill with the extra lighs in just cut down and then re-joined? are the outer lights rings the same size for my original mini lights? if hey hoy here we go, some on the bay as we speak, so with a quick answer from you could be on me way bud
Edited by splintercat, 02 November 2012 - 12:15 AM.
#8 1275GTS
1275GTS
  • 668 posts
  • Local Club: bmc
Posted 02 November 2012 - 10:00 AM
Yep the actual grille itself is the same height as the standard clubman grille and the light positions for the head lights are the same. You have to drill holes in the corners of the grille where the standard clubman grille screws by the head lights. As for sticking the grille back together I have now seen this adhesive called Q bond and it looks pretty good stuff. Its on ebay and amazon. I manged to pick up 3 grilles all with the hella spot lamps for about £20 each 2 years ago. Try and get the original spot lights with the grille as they are pretty good units and they are adustable for ease of levelling the beam pattern.
Hope this helps.
#9 1275GTS
1275GTS
  • 668 posts
  • Local Club: bmc
Posted 02 November 2012 - 10:03 AM
Also the top slat on the grille will need to have a slot cut out for the bonnet release handle.
#10 splintercat
splintercat
  • 616 posts
Posted 12 November 2012 - 07:49 PM
Right no problem getting the VW Golf Quad lite grille, no problem cutting it down ....The problem I am having is finding someone who has a grille badge. I already have a Clubman badge CZH651 69-75 mini radiator grille centre BUT i want either the CZH3874 mini and Leyland one OR CZH4145 Leyland one.......have asked in thw wanted section to no avail......Has anyone got one ? doesnt matter about its condition as I can get it refurbished easily enough................
#11 ClubbyAsh
ClubbyAsh
  • 149 posts
Posted 12 November 2012 - 08:03 PM
http://www.ebay.co.u...=item2ec2aab30b found this on ebay for you, i think it's a bit steep but if you're desperate then it's what you're willing to pay :)
#12 MINI WILL
MINI WILL
  • 559 posts
Posted 12 November 2012 - 08:14 PM
Link.
;D
#13 leaky
leaky
  • 6,890 posts
Posted 12 November 2012 - 08:34 PM
I have one of those kicking around you can have for £10 posted if you like. Its in alright nice. I sold one on ebay last week that wasn't as good for £14. Didn't realize they sold as well as they did ha.
#14 Daviewonder
Daviewonder
    Needs an extra inch!!
  • 1,020 posts
Posted 12 November 2012 - 08:54 PM
#15 ClubbyAsh
ClubbyAsh
  • 149 posts
Posted 12 November 2012 - 10:02 PM
Loving this!
