not have the rear fog and reversing lights for a 1986 mini city e? i assume if the fog light is not there it cannot fail
mot
mini-mad-dan
, Mar 30 2006 08:06 AM
5 replies to this topic
Posted 30 March 2006 - 08:06 AM
Posted 30 March 2006 - 08:43 AM
think you have to have a fog light. but you dont have to have reverse lights afaik
Posted 30 March 2006 - 08:46 AM
You eed the fog light, and it needs to work.. reversing lamps are not tested.
Posted 30 March 2006 - 08:50 AM
As i found out to my cost! I bought the car without a foglamp fitted and when i took it into the MOT station it failed because it was missing! if your car is registered after 1st April 1980 then a fog lamp MUST be fitted and working
Posted 30 March 2006 - 10:14 AM
As above, reverse lights are not a test item. There must be a rear fog light fitted to the os i believe, there must also be a fog light 'tell tale', eg the switch should be lit up when the fog light is on.
Theres a link in the faq's section to an online mot test book.
