mini cooper 2001 classic mini
Car run's great then when the radiator fan kicks in the side lights head lighs spot light have a small glow to them and when the fan gose off so dose the glow.
Every thing eles is working.
Only fault i found is that the fuse for the fuel pump via the cut off switch on the bulk head has a hint of melting to it.
Any clues please.
Electric Problem - Glowing Lights
ukcooper
, Nov 16 2012 08:04 PM
5 replies to this topic
Posted 16 November 2012 - 08:04 PM
Posted 16 November 2012 - 08:19 PM
Check where the wires run for the radiator fan switch.
The switch is behind the grill, lower front of the radiator.
I assume the wiring is running up and under the slam panel then upto the bulkhead. The headlight wiring also runs under the slam panel.
I would put a bet on that the fault is in the slam panel area somewhere, maybe a grill screw as broken through the insulation on the wiring behind and thus is shorting the connections and leading to the fault.
Posted 16 November 2012 - 08:35 PM
The mpi doesn't use the same loom as earlier modelsThe headlight wiring also runs under the slam panel.
Sounds like another earthing issue
Posted 16 November 2012 - 08:38 PM
My bad, i assumed the MPI wiring would run in the same place.
Posted 16 November 2012 - 08:45 PM
nah Mpi has a multi plug, that pokes through the inner wings for each headlightMy bad, i assumed the MPI wiring would run in the same place.
The earth point is on the bulk head for the headlights and the fan, there are 6 spade connections in one multi plug
Posted 16 November 2012 - 11:05 PM
Thank's for the reply's
Cleaned earth points, checked as much of the loom as possible for damage and try'd another battery.
Did notice tonight when it was dark that there was like a flash very intermtitant? from the behind the fuel gauge a blue one?
