Hi all,
Just a quick question, do all oil feed pipes changes from turbo to turbo or are they all the same?
As I need one for my hybrid turbo, which is a gt15/t2 with a 360 thrust bearing.
If they do change from turbo to turbo, which one do I need for my turbo?
All help really appreciated.
Bobby
Oil Feed Pipe
kappa
, Nov 19 2012 02:07 PM
6 replies to this topic
Posted 19 November 2012 - 02:07 PM
Posted 19 November 2012 - 02:26 PM
You should be able to see on your core what type you need. If there is a threaded hole there I believe that's the T2 type, and if there's a machined surface that uses an adapter and a gasket then i think that's the GT15 one.
Any idea which core you have? And pictures may be useful
Posted 19 November 2012 - 02:37 PM
Unfortunatly I do not know, but can upload some pics later on tonight when I am back home from work, but that is a big help, cheers
Edited by kappa, 19 November 2012 - 02:38 PM.
Posted 19 November 2012 - 02:49 PM
If you can put up some pics i'm sure people will be able to help more :)
Posted 19 November 2012 - 03:05 PM
Cool will do mate, cheers for that
Posted 20 November 2012 - 12:59 PM
my gt17 core has an m12 x 1.25 thread,
im using an adaptor - http://www.ebay.co.u...984.m1423.l2649 like this one to connect to my -4 oil feed pipe to block.
im not 100% sure the gt15 and 17 are same core though. - i took mine to the my local hydraulics place and tried fitting until i found the correct one.
Posted 20 November 2012 - 01:45 PM
Thanks for that info mossey2a, thats a big help, will look into this.
Bobby
Bobby
