Edited by xt_441, 19 November 2012 - 07:20 PM.
Koso Rx2N Dash On K20A
xt_441
, Nov 19 2012 07:18 PM
4 replies to this topic
Posted 19 November 2012 - 07:18 PM
Hi, Has anyone had any experience of fitting a Koso RX2N dash to a VTEC K20a? I'm looking for the best way to hook up the tacho and speedo.
Posted 20 November 2012 - 10:02 AM
What ECU are you using?
Posted 20 November 2012 - 04:44 PM
I'm using the Clockwise Motion Programmable ECU. I have a list of all the pinouts so I shall probably try the crank sensor for the tacho.
Edited by xt_441, 20 November 2012 - 04:46 PM.
Posted 21 November 2012 - 11:18 AM
My advice is get in touch with Clockwise and get some pointers on how to wire it up. In my experience the tacho out should be labelled tacho, not crank sensor.
I the ECU like a Hondata where it is fitted into the original Honda ECU housing and uses the same connectors?
Posted 21 November 2012 - 08:10 PM
Yes that's right; I've now found the rpm output from the ECU and it works a treat! Thanks for your comments.
