I have just stripped down my 998 A+ and am in the process of rebuilding it.
I am replacing the chain, oil pump, crank big ends and main bearings. However, can so one give me a list of what parts are single use, like the lock washers, crank bolt etc.
This is based on a full rebuild, I'm not leaving anything the chance so am replacing most things.
Obviously I will get a full engine and gearbox gasket set too.
Also what parts are recommended to change, the water pump is not that old but i figured its worth doing it now!
Do the followers or push rods need changing, none of them are marked or scored.
Alex
Help Needed With Engine Parts
AlexMozza
, Nov 25 2012 02:13 PM
5 replies to this topic
Posted 25 November 2012 - 02:13 PM
Posted 25 November 2012 - 03:57 PM
A complete engine and G/box gasket set, clutch case to block gasket, head gasket, oil pump gasket, complete lock tab set, you will need crank thrusts, mains shells, big end shells, cam shells, 8 new tappets, 8 new push rods,.........
Posted 25 November 2012 - 07:03 PM
With regards to the pushrods and followers I would change them but its up to you mate if they arent showing any scoring or signs of wear then you could get away with puttin them back in. Do check the pushrods are straight though because ive seen many a bent pushrod.
Posted 25 November 2012 - 07:26 PM
Would recommend only reusing cam followers if there are no signs of any pitting on the face, and you can be totally sure you are replacing them in exactly the same order they came out. Otherwise use new followers, they are not expensive.
As zippye says, the pushrods are fine to reuse as long as they are straight.
Posted 25 November 2012 - 07:53 PM
Cool, thanks!
Is there a pack of lock washers etc, or do they have to be bought individually, not a problem if the do, I was thinking more for ease.
Posted 25 November 2012 - 08:49 PM
I wouldn't get new followers unless they are really dead. New followers on an old cam isn't good on the lobes!
