camshaft
Posted 31 March 2006 - 04:58 PM
Posted 31 March 2006 - 05:15 PM
A asume that you are fitting an SPI engine to a carb car??? Why else would you be fitting a carb and mechanical pump.
Posted 31 March 2006 - 06:10 PM
no i am changing a spi cooper to carb as had up to the back teeth with the proplems with the ecu systemSPI cam is as a Carb cam and a mechanical fuel pump can be fitted.
Posted 31 March 2006 - 06:33 PM
Posted 31 March 2006 - 06:46 PM
would plug up the holes in the fuel lines and be safe and be much less hassle
Have you asked any one on here for help????????????????????????????????????????????
Injection to carb does happen mainly for the wrong reasons. Do be aware that it will be more difficult to get it through an MOT emissions test, though not impossible. Also your fuel consumption will deffinately get worse. Its worth sticking with the injection system and fixing it correctly.
http://www.theminifo...showtopic=20533
Posted 31 March 2006 - 07:14 PM
Posted 31 March 2006 - 07:41 PM
i just cant seem to get it to run right its overfueling the exhaust looks like a black hole, it never runs the same from day to day one min its running ok the next day its racing then just about ticks over then it sounds like its on three cylinders. and have noticed the exhaust is very loud it never use to be and its not that old, ta chrisI agree, fuel injection is far superior, why else would cars have changed over to it in the first place, because it allows more accurate control over fuelling! I would say that only change if you have exhausted all other possibilities.
Posted 31 March 2006 - 09:36 PM
Posted 01 April 2006 - 07:03 AM
With the std SPI unit, it is well known that approx 90hp is your limit, even with the MPI and the JCW conversion the hp was only 90...
Carbed minis are not restricted by such devices, and hence can be tuned to much higher levers...
Posted 01 April 2006 - 07:09 AM
Although you can fit a mapable injection system like Megasquirt, which would not cost you more than a webber or a set of Omega pistons.Carbed minis are not restricted by such devices, and hence can be tuned to much higher levers...
But then THIS ISN'T ON TOPIC.
Posted 01 April 2006 - 07:58 AM
If you go back and read my first post, I said that carbs are fitted to an injection engine mostly for the wrong reason. What this means and I shall spell it out, is, There is obviously a need to fit carbs when you reach the upper power limit and considered a good reason to fit them. However, fitting carbs just because you cant get it running right because you havent got a clue how the system works and cant find the fault is just plain silly. Fit the carbs and then have all the problems associated with then, needle selection, rolling road tune, struggling to get an injection car through the emissions test( and before any one says that it will pass, if you read my first post i said that it is not imossible to get it to pass), increased fuel consumption, not to mention the cost of the carb, manifold and filter. It would be far more sensible to fix the orriginal problem than run away from it and introduce a whole load more. Id opt to fix it.
Posted 01 April 2006 - 10:01 AM
Posted 01 April 2006 - 10:46 AM
i ask for help not insultsBut then who said that the engine was tuned past 90bhp
Posted 01 April 2006 - 10:53 AM
Posted 01 April 2006 - 05:22 PM
have changed plugs leads dizzy cap and rotor, lamda probe renewed small plastic bundy pipe new manifold gasket and today temp sender , goes like stink but wont tick over sound like have a hot cam in it but is standard, its not going to cost much to convert as have most bits ta chrisChris, MS is not trying to insult you, he's just asking what you've done to solve your injection problems so that it may be possible for someone to suggest something that hasn't been tried, rather than going out and having you spend hundreds of pounds on parts that aren't necessary!
