Dodgy Idle
harrymini2012
, Dec 03 2012 07:25 PM
8 replies to this topic
Posted 03 December 2012 - 07:25 PM
hi, my mini starts up fine and will sit idling but it seems like it is on the edge of cutting out and i give it a little rev to make sure it doesnt. is it just a case of it running a bit lean maybe? it has been sitting since mid september when i bought it and was off the road a year prior to that. any help would be appreciated, cheers
Posted 03 December 2012 - 07:30 PM
Try increasing your idle speed.
Has it got a carb?
Has it got a carb?
Posted 03 December 2012 - 08:05 PM
yeah it has a carb, theres some sort of adjustment screw then is there?
Posted 03 December 2012 - 08:08 PM
mine started doing that today after i fitted a new filter in the air box. i had an air leak so it leaned it off a tad so could be that. could also just need speeding up? put a colour tune in to see, wont do any harm.
Posted 03 December 2012 - 08:13 PM
ok cheers, how would i go about speeding it up then?
Posted 03 December 2012 - 08:16 PM
Yeah, just a screw. On the SU HS4 it's just a little Philips screw on the front-right as you look at it. Next to one of three flat-head screws that hold the dashpot (cover of the carb) down.
With the engine running, turn the screw clockwise IIRC to turn the idle speed up. You'll be able to tell when the idle is getting fast as it sounds like you're putting your foot down on the throttle.
I had to do this yesterday after getting my car back from a garage. I'll probably turn my idle down at the weekend. It's currently on about 2k RPM.
Edited by Mini Cheddars, 03 December 2012 - 08:17 PM.
Posted 03 December 2012 - 08:23 PM
thanks, will see how it goes tommorow
Posted 07 December 2012 - 07:38 PM
Any update on this?
Posted 08 December 2012 - 10:11 PM
forgot about this, got the mini out for a good run and is seems to have sorted itself out. think it may of been a issue from being off the road for a while. thanks for the help, harry
