How Do You Work Round The Rubbish Heating System?
57 replies to this topic
#1 Pewizzle
Pewizzle
  • 48 posts
  • Local Club: Southern Mini Owners Club
Posted 11 December 2012 - 11:50 AM
basically i spent 40 minutes this morning trying to defrost my car whilst my brother came along and was ready to go in 5 minutes because the heater in his car is actually productive, so i was just wondering if any of you have found a better way of keeping your car warm and get the best out of your heater, whether it is an external heater plugged in or what. i need help i can not deal with defrosting my car for 30 mins every morning as it is my every day car, so any suggestions?
#2 paul_s
paul_s
  • 415 posts
Posted 11 December 2012 - 11:56 AM
If you have a garage or somewhere under cover it's amazing how much difference it makes. Alternatively a sheet over the windscreen can save you having to scrape that.
My current routine is:
1) Start the car, and turn the rear screen heater on
2) Scrape the side windows, back first
3) Scrape the front windscreen, if necessary
Normally this means there's a bit of heat in the car by the time I start moving.
Not much but I hope this helps :-)
#3 minijules
minijules
  • 646 posts
  • Local Club: A's of Herts
Posted 11 December 2012 - 12:06 PM
take the glass out and it wont frost up :P
#4 charie t
charie t
  • 3,153 posts
Posted 11 December 2012 - 12:15 PM
Does your heater actually blow hot air?
The standard heater is really warm
#5 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 11 December 2012 - 12:17 PM
88c thermostat.
good condition cooling system
correct mixture and use of choke
maybe block of some of grill in really cold weather.
#6 minimaxie
minimaxie
  • 1,687 posts
Posted 11 December 2012 - 12:24 PM
Was going to say, the standard Mini heater is very warm! Mine is toasty in winter, perhaps too toasty!
#7 mk3 Cooper S
mk3 Cooper S
  • 5,569 posts
Posted 11 December 2012 - 12:43 PM
Get a car cover or top screen window cover. It will never compete with a modern system
#8 MrBounce
MrBounce
  • 2,661 posts
Posted 11 December 2012 - 12:45 PM
The heater, when in decent working order is generally quite good. It's the ventilation system that's usually rubbish.
Am incorporating an MGF system into the Midas to sort this.
#9 konyo
konyo
  • 1,107 posts
  • Local Club: Mini Freakz of Sussex
Posted 11 December 2012 - 12:48 PM
Agreed, mine gets really warm inside after about 10 mins.. No trouble with mine at all.
#10 cliche
cliche
  • 896 posts
Posted 11 December 2012 - 12:50 PM
I flushed, stripped, cleaned and changed the sealings on mine after following a couple of guides on here.
#11 minimaxie
minimaxie
  • 1,687 posts
Posted 11 December 2012 - 12:55 PM
I reckon OP you need flushing the system, something might be cought in there like gunk thats stopping the heat get through
#12 paul_s
paul_s
  • 415 posts
Posted 11 December 2012 - 12:59 PM
Sounds like I may have to do that too - mine's warm, but not roasting. I normally have it on full blast for most of my commute by which time it's warm, but only after about 45 mins do is get really warm.
#13 SA MINI
SA MINI
    Previously known as shaunarmes.
  • 1,001 posts
  • Local Club: yet to join HAMOC
Posted 11 December 2012 - 01:22 PM
Until the engines warm there's no point turning the heater on because effectively your just adding another radiator with the cooling fan turned on lol
Taking longer For the mini to warm up
#14 charie t
charie t
  • 3,153 posts
Posted 11 December 2012 - 01:25 PM
Its not running through the radiator until the engine is warmed up, and thermostat opens anyway
#15 SA MINI
SA MINI
  • 1,001 posts
Posted 11 December 2012 - 01:27 PM
I know , just takes longer.
Does on mine anyway
