How Do You Work Round The Rubbish Heating System?
#46
Posted 12 December 2012 - 11:57 AM
#47
Posted 12 December 2012 - 04:00 PM
#48
Posted 12 December 2012 - 05:28 PM
#49
Posted 12 December 2012 - 05:34 PM
ive blanked off half my grille which saves the 'lectrics from water too.
#50
Posted 12 December 2012 - 07:26 PM
i always thought minis didnt like being left to warm up idling, thought it was better to just get moving?
It's not a question of not liking to be warmed, it's about fuel economy. If you leave your car running for 6 mins you could of driven for 1 mile using the same fuel.
If you can't see out of the windows you or someone else could be dead.
Which is best?
Cardboard inside the grille does help. In Winter you can put it all the way across as there is enough air flow from under the subframe for it not to overheat. Just don't forget to remove it in Spring.
#51
Posted 12 December 2012 - 07:51 PM
i was just always led to believe minis really dont like warming up on idle and its more beneficial to warm up on the go.
clear the outside with a scraper, chamios the inside as needed.
#52
Posted 12 December 2012 - 09:03 PM
wow, i didnt say dont clear your windows!
I've always thought it's best for any car not to be left idling for no reason. I do what you said; clear all the glass then start the car and go.
#53
Posted 12 December 2012 - 10:32 PM
I generally have to de ice my car in the car park at work after a night shift. When I do, I go outside, start her up, then go back inside in the warm for a cuppa for 10 minutes. There's no way I'm standing outside with a scraper after a 12 hour night shift, when it's -4 C! (like it was this morning). Besides my engine idles for longer than that whenever I'm stuck in traffic and I'll happily burn 40ish p's worth of unleaded whilst poking two fingers up at the environmentalists, if it means me not freezing my ass off!!
#54
Posted 12 December 2012 - 10:41 PM
It's the bit between the heater and the windscreen that is crap! But once the engine is warm just enough heat reaches the screen to stop my breath re-freezing on the screen.
Does anyone know how to improve the vents coming out of the dash?
#55
Posted 12 December 2012 - 10:49 PM
It's not a question of not liking to be warmed, it's about fuel economy. If you leave your car running for 6 mins you could of driven for 1 mile using the same fuel.I've always thought it's best for any car not to be left idling for no reason. I do what you said; clear all the glass then start the car and go.
haha fair enough I reckon after a 12 hour shift at -4 C you're excused
I thought it's all about oil pressure being low at idle so less lubrication so more wear and with carb engines like minis you could get bore wash.
#56
Posted 12 December 2012 - 11:11 PM
#57
Posted 12 December 2012 - 11:37 PM
I think pouring a pan of boiling water over your frozen windscreen is always a great idea!!
Luke warm water would actually work.
But I pitty the fool that pours boiling water on a frozen windscreen.
#58
Posted 12 December 2012 - 11:43 PM
My mini currently doesn't have a windscreen but it is wrapped up in a dust sheet!
