You were asked about, nobody has told you it was definately
i have the same problem.
I was told........
The "4 hour diagnostics" should have revealed a problem if it was carried out by a trained technician, The more details you can give the easier it makes. If you could give the readings from live data, it could point to the area you want to look at.
Unfortunately people assume that a computer will simply say, bingo thats your faulty part, most of the time it will, but in some cases it needs somebody to take the readings, test and understand what is going on.
Guess work costs and does not always solve the issues.
Not sure what your point is, but to be clear, everything i was told i was paying for.
The guy that did the daig was arranged by one of the most highly respected mini specialists in the south east...I was not there during the work as the car was left with them for a few days to find this problem, no one should be guessing on my tab, but they do it would seem.
At the end of the diag work I was told as fact it was something mechanically wrong in the engine... that now looks like a bit of a guess.
Edited by Ruckus, 18 December 2012 - 11:51 AM.
