1310 Engine & Power Figures
Posted 20 December 2012 - 04:51 PM
1310cc Stage 2 engine
10.5:1 compression ratio
AE 21253 +.040 Cast pistons
Crankshaft reground, new Vandervell comp bearings and thrusts
A+ Conrods balanced
Kent megadyne 286, steel faced oil pump & duplex timing chain kit
Stage 2 ported and polished cylinder head with bosses removed, 35.5mm inlet, 29mm exhaust triple collet valves fitted with 185lbs double valve springs
Turbo verto clutch assembly
Rebuilt gearbox using all new bearings, baulk rings, choice of final drive ratio, uprated diff pin & central oil pickup pipe
Posted 20 December 2012 - 05:10 PM
AC
Posted 20 December 2012 - 05:20 PM
also could look at vizards book on tuning carbs up :)
Posted 20 December 2012 - 05:21 PM
Posted 20 December 2012 - 05:26 PM
Posted 20 December 2012 - 05:44 PM
AC
Posted 20 December 2012 - 06:04 PM
The engine would be powerful enough to make the clutch slip when worked hard in my experience.
AC
In theory you can make any clutch slip when worked hard.
Posted 20 December 2012 - 07:06 PM
Posted 20 December 2012 - 07:23 PM
Posted 20 December 2012 - 07:50 PM
you dont say engine is fully balanced
which in my opinion needs doing putting in a 286
its only a stage 2 head 266 276 be better
mines only got mg metro cam with stage 3 head
and its great to drive
Posted 20 December 2012 - 08:20 PM
If it's your daily driver then I strongly recommend the 266 with 1275 motor. If you're looking for a bit more grunt at the top end then the 266 with higher lift rockers works well.
I don't know how much power this would be down on the 286, but the torque up to about 2500rpm will be much stronger with the 266, where it's useful in traffic.
And the 266 will give you much better mileage.
Posted 20 December 2012 - 10:24 PM
In turn that means a lower final drive ratio is needed which will reduce cruising speed, or put the same cruising speed at higher revs.
And yes, you'll need a stronger clutch diaphragm.
A 286 is a far from ideal road cam due to the high revs needed to make it work. With a 286 the engine will need rebuilding much more often due to the high wear rate caused by the constant high revs.
Edited by Cooperman, 20 December 2012 - 10:24 PM.
Posted 20 December 2012 - 10:58 PM
Posted 20 December 2012 - 11:59 PM
