Carburetor Issue
#16
Posted 24 December 2012 - 12:54 AM
What do the plugs look like?
Can you do a compression test?
Does the carb piston rise and fall easily(did you centre the jet after changing it?)
Have you tried advancing the timing as it could be way to retarded?
#17
Posted 24 December 2012 - 09:13 PM
So I turned the jet adjusting nut all the way in and then backed off 12 flats. The car would not start. I had to turn it an additional 12 flats to get it started. I’m assuming there’s something wrong with the fixed jet I put in. So the HS4 is off the car.
I’m going to switch back to the waxstat jet and see what happens. The only needle I have is the aaa spring loaded. Can you use a spring loaded needle in a fixed jet? Maybe that’s the problem.
#18
Posted 24 December 2012 - 09:54 PM
#19
Posted 24 December 2012 - 10:23 PM
#20
Posted 24 December 2012 - 10:36 PM
#21
Posted 24 December 2012 - 10:53 PM
It certainly sounds like a fuelling issue somewhere along the line. I can assume your float level is correct?
#22
Posted 24 December 2012 - 11:07 PM
Earlier a couple of us assumed your carb is an HS4. Rev the engine until it starts to stumble badly. Immediately switch off while the engine is under duress. Remove the lid from the float bowl and see how much fuel is in the bowl. Let us know what you find.
#23
Posted 26 December 2012 - 02:28 AM
Well I tried what dklawson recommended and found that I had a sticky float valve. I changed it and still had the problem, but the bowl is now filled with gas. Even after changing the float valve it still needs 24+ flats to get it running.
It’s a HS4 with a stock cam. The only things that were changed were the needle (aaa), intake (1.75” diameter), RC40 exhaust and a K&N air filter. The HS4 spacer is tapered from a 1.5” (carb side) to a 1.75” (intake side). I guess I wanted a smooth flow into the manifold. The gasket on the manifold is a HIF6 so the air doesn’t hit the gasket entering the manifold.
I took a video of the problem.
#24
Posted 26 December 2012 - 08:59 PM
By the way I have an HS4 which was recently switched from waxtat.
Edited by indymini, 26 December 2012 - 09:00 PM.
#25
Posted 27 December 2012 - 12:58 AM
#26
Posted 27 December 2012 - 10:48 AM
I think you're barking up the wrong tree with the carb, try rotating the dizzy clockwise until the revs start to increase.
#27
Posted 29 December 2012 - 05:02 PM
#28
Posted 29 December 2012 - 05:09 PM
- Start engine and run till warm
-Slacken dizzy and set engine to fast idle
- Rotate dizzy till you get the fastest engine note.
- Tighten dizzy and take for a spin.
If the car pinks then rotate the dizzy slighty anticlockwise and try again, repeat until no pinking/running on.
If the car feels sluggish then rotate the dizzy clockwise till it pinks and follow the above.
#29
Posted 29 December 2012 - 07:50 PM
#30
Posted 29 December 2012 - 07:53 PM
I usually, hold the throttle open with one hand and rotate the dizzy with other(who says men can't multi task!!)
One thing I missed was that if you try and restart the car once you've altered the timing and it hesitates then its also too advanced.
You'll soon see if it makes a difference though.
