Is this just a thing I should get used to or should i drill a pinhole at the bottom of the door to let it drain?
Rain Water In Doors
TehMarchant
, Dec 23 2012 01:08 PM
6 replies to this topic
Posted 23 December 2012 - 01:08 PM
So I guessed that rainwater will get into doors, but how much, mini is filled till the fisrt hole and it had ruined my old door cards and I dont want the same again.
Posted 23 December 2012 - 01:12 PM
drill a few holes one in the middle & one at each end..
Do you have the chrome strip on the top of the door skin (outer)?
Posted 23 December 2012 - 01:13 PM
yeah i have a chrome strip, i will put a pic up and you can judge if i need a new seal there. cheers for the quick responce
Edited by TehMarchant, 23 December 2012 - 01:15 PM.
Posted 23 December 2012 - 01:21 PM
In the pictures you can see the gaps, will these need fixing or will it be okay?
Posted 23 December 2012 - 01:25 PM
your door should already have holes in the bottom of it
just unblock these holes and fit a new membrane between the door and the door card
once we get some warmer weather stick some waxoyl in the bottom, doors rot from the inside out
Posted 23 December 2012 - 01:31 PM
you could put ducttape over the holes between the doorcard and door, to stop the water coming through to the doorcards?
Posted 23 December 2012 - 02:03 PM
That is acctually somthing I will do, that is a good idea.
Okay all tapped up, holes remade, will put the cards back in tomorrow if i can get more clips/pins as some broke and some were missing.
Edited by TehMarchant, 23 December 2012 - 08:05 PM.
