http://www.moss-euro...teIndexID=21365
Before anyone says I know it is easy to make one but this is not for me
Posted 23 December 2012 - 04:49 PM
Posted 23 December 2012 - 05:49 PM
Posted 23 December 2012 - 06:45 PM
Posted 23 December 2012 - 07:17 PM
Posted 23 December 2012 - 10:31 PM
Posted 23 December 2012 - 10:35 PM
I recommend being VERY careful about what you do to your headlight wiring. If they fail completely when driving on a dark road at night, a serious accident is very likely. In particular, it is both illegal and dangerous to have a single fuse which will kill both lights if it blows.
Posted 23 December 2012 - 10:58 PM
The standard setup has one feed, is that illegal?it is both illegal and dangerous to have a single fuse which will kill both lights if it blows.
Posted 23 December 2012 - 11:33 PM
Posted 24 December 2012 - 10:07 AM
Posted 24 December 2012 - 01:04 PM
Posted 24 December 2012 - 01:40 PM
Posted 24 December 2012 - 04:09 PM
Posted 28 May 2014 - 12:00 PM
If you wire up the headlights with a set of relays and fuses, should a main-beam fuse blow and there is only one fuse then all the main beam lights go out, so you need two relays and two fuses for the main beams, one each. The same applies to the dipped beams. That is 'fail-safe' electrical design and is the correct way to do it, as Tiger will, I'm sure, confirm.
The original wiring is another matter, but one might assume that the reason for wanting to 'relay' the headlights is to allow for up-graded more powerful bulbs.
Holy thread resurrection Batman!
Confused! Are we saying the relays in the OP aren't adequate and we need twice as many relays? I can't find a kit or wiring diagram for 4 relays, I just want to upgrade from my sealed beams to H4s.
Posted 28 May 2014 - 12:10 PM
Edited by Dan, 28 May 2014 - 12:14 PM.
Posted 28 May 2014 - 12:43 PM
Cheers Dan, don't suppose you have a wiring diagram for a four relay set-up? I can follow instructions but I can't write them. Not where electrickery's involved anyway
