Headlight Relay Kit
26 replies to this topic
#16 darkrider
darkrider
  • 71 posts
  • Local Club: E.P.Veteran Car Club
Posted 09 November 2020 - 04:44 PM
Hi What I want to know is what wires go where in a relay system??
#17 KTS
KTS
  • 2,490 posts
Posted 09 November 2020 - 04:56 PM
have a read of this - should help
https://www.12voltpl...elay-guide.html
#18 Spider
  • 15,684 posts
Posted 09 November 2020 - 05:47 PM
That's a pretty comprehensive guide !
#19 darkrider
darkrider
  • 71 posts
Posted 10 November 2020 - 08:30 AM
Hi Moke Spider so if I want to put a relay between my headlight and the loom I must just slice it in?
#20 MiNiKiN
MiNiKiN
  • 217 posts
Posted 10 November 2020 - 12:15 PM
Edit: Altough I would rather have a 4 relay / 4 Fuse setup. I.e. separate circuits for left and right, just in case one supply fails right at that blind corner.... you are left at least one-eyed rather than totally blind, if you catch my drift.
Edited by MiNiKiN, 10 November 2020 - 12:18 PM.
#21 gazza82
gazza82
  • 3,086 posts
  • Local Club: TMF+
Posted 10 November 2020 - 02:10 PM
The existing wiring becomes the low voltage side .. so blue/white or blue/red to the activation coil then the other side to earth. Pins 85 & 86.
You run a new feed from the battery/fuse to the high voltage side and from there to the head or dip beam. So 30 and 87.
#22 Bobbins
Bobbins
  • 1,525 posts
Posted 11 November 2020 - 08:01 AM
.... I suspect you might mean low/high current rather than voltage :)
#23 bob01b
bob01b
  • 12 posts
  • Local Club: NEMO
Posted 12 November 2020 - 01:19 AM
Attached File  63 Mini relay wiring diagram.pdf   122.79K   94 downloads
Here is my wiring diagram.  No cuts to the factory loom.
Regards, Bob
#24 gazza82
gazza82
  • 3,086 posts
  • Local Club: TMF+
Posted 14 November 2020 - 05:52 PM
Probably ...
#25 beardylondon
beardylondon
  • 1,725 posts
Posted 16 November 2020 - 04:20 PM
Hi Bob
This is very interesting, is this similar to what Wired by Wilson sells?
attachicon.gif 63 Mini relay wiring diagram.pdf
Regards, Bob
#26 bob01b
bob01b
  • 12 posts
  • Local Club: NEMO
Posted 17 November 2020 - 12:49 AM
Attached File  IMG_1573.jpg   37.32K   19 downloads
Beardylondon,
Not sure.  From the picture on his website, Wilson's product has two relays, likely one for high beams, one for low like mine, but has 4 fuses.  Possibly has the fuses on the output side of the relay, to fuse left and right separately.  Here is a picture of my installation FYI.
#27 beardylondon
beardylondon
  • 1,725 posts
Posted 17 November 2020 - 10:45 AM
Thank you, very neat install!
