After the dry build comes the actual engine build:
Purchased a kent MD274 camshaft to use, should give good driveability with the relatively high compression
Got the cam in, lubed and timed:
And finished building up the timing cover.
Also got a refurb kit for the plated clutch master cylinder:
Brakes the same colour as the g/b, built up with mintex pads
Alternator modified so the pulleys line up:
Then I finished the shimming of drop gears and assembled the parts onto the engine
Then fitted the high flow 1275 oil pump i'd modified for the 998 cam arrangement
Then I could fit the idler gear and transfer case
Then to help close up the holes to keep dust out etc, I dummy fitted the wok and cylinder head.
Which brings us to sep 15! being held up by money as I need parts to finish the engine build, and i found some small holes in the floor that need patching. Doesn't help that the 'reliable' daily blew a headgasket... Hopefully progress soon of welded car, painted car, complete wiring loom, complete engine and then boost!!!
