i want to put a cigarette lighter in so i can use my sat nav can i just wire of the live for the stereo or what other ways of doing it is there ?
Help With Electrics
mike-blair04
, Jan 01 2013 04:46 PM
4 replies to this topic
Posted 01 January 2013 - 04:46 PM
Posted 01 January 2013 - 04:49 PM
Live off fusebox and an earth, easy
Posted 01 January 2013 - 05:30 PM
As above and if you have the 4 glass fuses box wire it on the third one down. This will allow it to work with the ignition so that the battery won't drain while switched of.
Posted 03 January 2013 - 12:49 AM
Make sure you use suitable size wiring as a lighter socket can draw a bit of current
Posted 04 January 2013 - 05:42 PM
You could also run a new line from the main feed if you wish.
