Float Chamber Angle ?
25 replies to this topic
#16 bmcecosse
bmcecosse
  • 9,699 posts
Posted 04 January 2013 - 08:48 PM
That pancake filter is hopeless - far too thin - it's costing you power! But sort out the float bowl first.......
#17 IainNeon91
IainNeon91
  • 1,287 posts
Posted 04 January 2013 - 11:06 PM
I have been looking into a cone filter today, so should get one soon.
I would have kept my K&N element box filter but it wouldn't fit on from the angle the carb sits :mmkay:
#18 The_Doc
The_Doc
  • 37 posts
  • Local Club: www.dcmoc.co.uk
Posted 21 June 2023 - 01:39 PM
This is going to be a 10 year thread revival, not sure why it's not been discussed more though.
I've seen it written in lots of places that all minis with HS carbs need a 30° angle to get the float bowl horizontal given the angle of the inlet manifold and carb assembly. But I can't be the only one to notice that the angle on a single hs4 is nowhere near as steep as on twin HS2 carbs, or even I think on some single hs2s on very old 850s. Just by eye they look different, so are we sure they are all 30?
My single HS4 looks like a 10 degree angle but can't measure it to be sure. Would welcome a list of carbs and float angles if such a thing could exist?
#19 nicklouse
  • 18,998 posts
Posted 21 June 2023 - 03:06 PM
The angle is different due to the need to clear the bulkhead. When fitting single carbs to a twin manifold you need to change the angle of the float chamber. You did not on the Inline engine as there was no bulkhead in the way.
#20 The_Doc
The_Doc
  • 37 posts
Posted 21 June 2023 - 03:13 PM
But what about single carbs to a single manifold?
#21 Ethel
  • 26,580 posts
Posted 21 June 2023 - 03:57 PM
Can't be that critical or we'd never be able to drive up 'n down hills. The level in the jet is what really matters, so if tipping the float chamber keeps the juice level with that it should be good enough.
#22 Lplus
Lplus
  • 990 posts
Posted 21 June 2023 - 04:52 PM
You would need to measure the angle.  Burlen produce 4 different grommets to provide 0, 10, 20 and 30 degree angle depending on which hand the carb is.
#23 The_Doc
The_Doc
  • 37 posts
Posted 21 June 2023 - 04:58 PM
So in conclusion the mantra that all minis are 30 degrees is incorrect?
#24 Lplus
Lplus
  • 990 posts
Posted 21 June 2023 - 05:13 PM
Yes.  Twin carbs on minis are 30 degree whilst twin carbs on sprites are 20 degree.  The single 1 1/2 " off my 1100 clubman estate is 10 degrees.  I don't know what 11/4 su's sit at.   To add to the fun the grommets can be solid or flexible.
#25 Spider
  • 15,684 posts
Posted 21 June 2023 - 06:10 PM
The angle isn't that critical. The level of the fuel in it much more so.
#26 Ethel
  • 26,580 posts
Posted 21 June 2023 - 11:17 PM
I suppose if you were to extend an axis from the fuel level in the jet, you'd want it to run through the float chamber so the  volume below it remains constant regardless of angle. Though the float ought to compensate too as it's attached to the float chamber (maintaining the same tilt as it) and will displace a constant volume.
The nearer to horizontal the float pivot is, the freer it's likely to move - so maybe that's why less incline is best???
