Mpi 2000 Engine Problems - Rebuild
19 replies to this topic
#16 llelkes
llelkes
  • 13 posts
Posted 02 September 2013 - 06:12 AM
Have you done anything with the idle air control valve? cleaned it/changed it/checked for cracks on the housing?
not yet, will check, thanks
the O2 VOLTS. BNK. 1 4,27 is ok? i think the o2 sensor should return values between 0,9-0,2 volts
#17 llelkes
llelkes
  • 13 posts
Posted 03 September 2013 - 08:41 AM
HI I checked the idle air control valve - sbz008 3454, seems to be ok, housing also - not broken, clean.
O_O
Other thing what I tried to disconnect O2 sensor - read value is 1,8 - the engine was running - nearly stopped
but ACR did not found any error codes - is it ok?
Thanks,
Laci
Edited by llelkes, 03 September 2013 - 08:42 PM.
#18 llelkes
llelkes
  • 13 posts
Posted 06 September 2013 - 07:32 AM
HI I changed the idle air control valve - same behavior ... :wacko:
Edited by llelkes, 06 September 2013 - 07:36 AM.
#19 Fast Ivan
Fast Ivan
  • 2,911 posts
Posted 08 September 2013 - 04:22 PM
the lambda should be constantly changing as you say, is the value of 4.27 stuck or does it go up and down, with the 4.27 being the max?
also the MAP sensor is quite high
#20 llelkes
llelkes
  • 13 posts
Posted 13 September 2013 - 08:59 AM
The values at idle are between 4,29-4,31 if I give and release gas they are jumping form 0 to 4,4 - if I disconnect the lambda then I did not got any error - is it ok?
Thanks,
Laci
