Leaks!
Posted 05 January 2013 - 01:19 PM
I'm open to any suggestions.
Posted 05 January 2013 - 01:29 PM
Water collecting in the floor can come through the check strap seals or through the door itself.
Posted 05 January 2013 - 01:34 PM
Posted 05 January 2013 - 01:46 PM
or the front screen
The front screens been done.
Posted 05 January 2013 - 01:49 PM
You should never need sealant. Are you absolutely sure it's coming through the main seal?
We've got all the carpets out and with a hose pipe on it a small trickle of water comes over the inner sill about midway. I, just assuming its the door seal. I have replaced both sides check strap seals.
Posted 05 January 2013 - 01:50 PM
Can you physically see water coming in by the door seal?
Sorry you beat me to it lol
Edited by corrado vr6, 05 January 2013 - 01:51 PM.
Posted 05 January 2013 - 01:55 PM
Are the carpets wet?
Oh yes!!!!
Posted 05 January 2013 - 02:10 PM
Posted 05 January 2013 - 03:52 PM
Posted 06 January 2013 - 09:25 PM
I think the seals on the right way round, just put it on the same way as the old one.got the seal on the right way round? theres an inside an out
Posted 06 January 2013 - 09:26 PM
is the water getting inside the door, coming out behind the door card and dripping down the bottom of the door onto the top of the rubber ?
+1. Check the drain holes insdie the door to see if they are bunged up.
Posted 06 January 2013 - 09:30 PM
Nope, it looks like its actually coming down the seal. The door card plastic has already had silicone on to seal themis the water getting inside the door, coming out behind the door card and dripping down the bottom of the door onto the top of the rubber ?
Posted 06 January 2013 - 09:31 PM
Holes are clear, ive had a hose on it and I can see the water coming in
Posted 06 January 2013 - 09:35 PM
Posted 06 January 2013 - 09:37 PM
How will I know if its not?Is the door sitting properly in the cutout. have a look at the window frame at the top.
