My Mini Daily Driver/ Slow Resto Project
#16
Posted 25 January 2013 - 01:30 PM
#17
Posted 25 January 2013 - 01:37 PM
#18
Posted 25 January 2013 - 01:48 PM
I used to have a 65 Mustang-
But this is what happened to her-
#19
Posted 25 January 2013 - 02:05 PM
#20
Posted 25 January 2013 - 06:47 PM
are those golf cart wheels and such safe for road use on cars?there are much higher speeds on minis,thats why i ask...
i hope you were ok after the accident with the mustang,and the passangers aswell...
#21
Posted 25 January 2013 - 06:55 PM
Luckily I was the only one in the Mustang, I was okay, but it messed up my knee a bit, and bruised a couple of ribs. The Mustang (Sally, lol) had a roll cage and 5 point harness. Despite the harness, I still hit the dash hard enough to bend it. The knob for the headlamps came off and the rod stabbed me in the knee, but I didn't even notice for a half hour, haha. After the wreck, she was about 2 feet shorter than before.
The other guy, also in a Mustang (1999) was fine.
#22
Posted 28 January 2013 - 11:29 PM
Did a little work to Flur today and she is finally starting to look like a Mini! Got some used wheel arches to put on her, and painted the steel wheels silver for now, until I get some real wheels, just so she doesn't look bad with the dirty mismatched steel wheels. Also went under the car today with a wire brush and some rust converter just to stop all of the surface rust from becoming a major problem. Also under coated the whole car today too.
New brakes on the rear-
Made a scary realization... I think I could park Flur inside my SUV, haha-
You can see some of the damage to the rear end in that picture.
Unfortunately, while I was under the car, I found a small coolant leak. It's not a big deal, I was planning on redoing the entire cooling system anyway, I will just be doing it sooner rather than later.
I didn't get any pictures of my garage/boot handle experiment on the car, because my phone died, BUT, it fits perfectly, no modifications needed at all. The mounting holes on the handle line up perfectly with the holes in the boot lid, and the square peg is the exact same size as the correct boot handle, so the garage handle works perfectly with the original latch! 4.gif The only thing I will have to do is trim the peg a bit.
Took these pictures earlier when I was testing to see if the two parts would work together-
And finally, the obligatory photo shoot edits
#23
Posted 07 February 2013 - 07:27 PM
The leak was just a spit hose, but I knew that the radiator would need to come out anyway, so I bought a new one, and I am really glad that I did. If you just touch the fins on the old radiator, they fall off, haha.
Old-
New-
That's about as far as I got on the cooling system today, because my new hoses hadn't arrived yet. So I went about getting some of the little things done that I need to do before she goes on the road... Cleaned up all the grounds, got the tail lights in, and blinkers working, finished fitting the interior (save for the carpet), took the grille off so that I can try to fix it, etc.
All that's left to do before I can start driving her everyday is to refit the cooling system, put in some seat belts, and new headlamps. Then she's good to go.
I feel like I took a step back though, cause she started the day like this-
and ended like this-
#24
Posted 07 February 2013 - 11:52 PM
Flur will not be perfect by any means, she is just a daily driver, but I can't stand the bent up grille with half the slats falling off, but I also don't want to spend the money on a new grille that will look better than the rest of the car, so I decided to try to bend the slats back as best I could, reattach them, and polish it up.
Before-
Taped up to keep from scratching the slats and to paint the metal backing. I kind of like the green slats... but I don't think it would be a good look for Flur-
After-
Still not perfect, but A LOT better than before, and it was cheaper than even buying a used grille, which would have looked about the same. All in all, I am happy with it.
#25
Posted 08 February 2013 - 12:52 AM
In Ireland. Keep up the good work!
#26
Posted 08 February 2013 - 01:31 AM
#27
Posted 08 February 2013 - 08:13 PM
Great job so far mate! I bet your itching to get her on the road. Loved Sally too. Beautiful car which you don't see here
Thanks. Yeah I miss Sally quite a bit. I love the Mini, I haven't been this excited about a car since Sally. She's also the first car that I have named since then too, haha.
not a bad starting point. wish mine started like that instead of a rust pit!!
Well believe me, she does have her share of rust, but luckily it's not too bad. The biggest issues are mostly cosmetic.
Speaking of cosmetic, I did a little more cleaning up today....
The fan shroud was pretty rough looking, and I wanted to spruce it up so it didn't look even worse when I put in the shiny new radiator.
Before-
After a bit of work with some steel wool, and some paint, it ended up like this-
Not perfect by any means, but a ton better to look at, and perfectly usable for a daily driver :)
Sorry I keep boring you guys with all this little stuff, I am just trying to keep a good record of all the work I am doing to Flur.
#28
Posted 08 February 2013 - 08:40 PM
#29
Posted 09 February 2013 - 03:22 PM
#30
Posted 13 February 2013 - 08:59 PM
I've got the cooling system refitted. It's running just a little warmer than I would like it to when sitting at an idle for a long period of time, but I will soon rectify that with a full time electric fan.
New exhaust arrived today! Well not new, it's used, but used very little. I'm still not sure how it will sound, it's just an RC40 resonator (front box only) set up with a centre exit. I couldn't pass it up for the price. If I don't like the sound, back up on ebay it will go.
The exhaust might not go on for a while as it is not really a priority, it was more of an impulse purchase. Now I am just waiting on my new tyres, tail lamps, and carpets.
