Hi what is the best fuel system to run on a supercharged conversion?
I will be running a 1330 with a blow threw set up. Was just wondering if I'm best to get a spi/mpi tank or just use my standard carb tank and run a facet or similar external pump.
Clive
Supercharged Fuel System
clivemk1mini
, Jan 07 2013 08:45 AM
6 replies to this topic
Posted 07 January 2013 - 08:45 AM
Posted 07 January 2013 - 08:51 AM
If blow through you'll need al the metro turbo gubbins:
Carb
plenum
pump
fuel pressure regulator
feed and return piping
If you use the Spi or Mpi tak it make pluming it up easier. The Spi pump will only alow around 10psi, but that's the realistic limit of the M45 anyway.
Carb
plenum
pump
Posted 07 January 2013 - 08:54 AM
Thanks. I already have the carb and plenum. I wasn't sure which was my best option for the tank etc. hopefully the car will be back at the weekend so I can start building it all
Posted 07 January 2013 - 05:34 PM
As wil says....
I will ad though... that you can use the SPI tank and replace the pump with an in tank one form a modern injection car ( fiesta honda etc) and run more boost.
Posted 07 January 2013 - 07:53 PM
Cheers for the info
Posted 07 January 2013 - 10:46 PM
Get on Turbominis.co.uk My friend.
Posted 08 January 2013 - 07:33 AM
Will take a look cheers
