1275 Automatic Conversion To Manual
24 replies to this topic
#1 Minilad96
Minilad96
  • 10 posts
Posted 15 January 2013 - 03:16 PM
To change the 1275 auto to a manual is it simply a gearbox change?
#2 Mini_Alex
Mini_Alex
  • 175 posts
  • Local Club: East Devon Mini Club
Posted 15 January 2013 - 03:22 PM
Auto's have a different subframe to manuals, so there will be more work than just a gearbox change.
Alex
#3 sweetytp
sweetytp
    Just On Tickover
  • 6 posts
Posted 15 January 2013 - 03:25 PM
What you 'll need are :
A manual gear box with it's remote gear stick assembly
A manual gear box front subframe
The manual gearbox driving axles for your car (drum brakes or discs and what size cooper S or 8.4")
#4 miniman24
miniman24
  • 1,696 posts
Posted 15 January 2013 - 03:26 PM
I think the engine blocks are different too, different gearbox mounting points. Easiest way is a complete manual engine with gear shifter and 2 auto to manual engine mounts :)
#5 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,146 posts
  • Name: Sean
Posted 15 January 2013 - 03:27 PM
Nope, the automatic engine has a lot of differences to the manual one. Its not a case of just fitting a manual gearbox to the auto engine block.
It is possible but takes quite a bit of engineering,
#6 danm
danm
  • 502 posts
  • Local Club: Stringfellows
Posted 15 January 2013 - 03:54 PM
I thought you could just use the same driveshafts? Provided it matches, say a 998 A+ auto can use the same driveshafts as a 998 A+ manual?
Add to your list new clutch master + slave cylinder and a pedalbox/clutch pedal.
The whole engine + gearbox as one needs to be swapped, unless you
#7 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 15 January 2013 - 04:08 PM
You need to change the whole engine or have access to a machine shop where you can re-engineer the engine block.
You can use the auto subframe with some adapter mountings, however, my preferred technique is to replace the subframe for a manual version, it's a lot neater, and also gives you a chance to overhaul the front suspension while you're there..
You will also need, apart from a manual engine/gearbox/clutch etc
A remote gear change, a clutch pedal and appropriate spring for the pedal box, a clutch master, pipe and slave if one does not come with the engine
#8 Minilad96
Minilad96
  • 10 posts
Posted 15 January 2013 - 07:13 PM
I guess it's easier just paying the extra for a manual 1275
#9 Scott@minispeed
Scott@minispeed
  • 200 posts
Posted 15 January 2013 - 07:21 PM
quickest/cheapest trick for fitting manual engine in auto front subby is to fit a manifold washer under each of the fixing points between the alloy mounting on the side of the gearbox and the gearbox. This is the same mounting that the radiator bracket / engine mount attaches too. You will need to redrill one of the engine mount holes in the subframe or use the auto mount.
Edited by Scott@minispeed, 15 January 2013 - 11:01 PM.
#10 minilee94
minilee94
  • 3,523 posts
Posted 15 January 2013 - 07:35 PM
Iv just done the conversion and you need
Gear linkage
Pedal for clutch
Master cylinder
Slave cylinder
Engine and box
And you can get auto to manual conversion mounts
#11 minilee94
minilee94
  • 3,523 posts
Posted 15 January 2013 - 07:38 PM
Why are people saying you need a remote gearbox you dont as when replacing the grear linkage the tod links straight to the gearbox
#12 iDemonix
iDemonix
  • 963 posts
Posted 15 January 2013 - 07:42 PM
I'll be doing this swap at some point when I can figure out the logistics of a 1-man-front-subby-swap.
Mine is a 998cc auto going to a 1275 manual, do I need new drive shafts?
#13 minilee94
minilee94
  • 3,523 posts
Posted 15 January 2013 - 08:30 PM
Nope same shafts i dont know if u need different inner joints tho i dout it
#14 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 15 January 2013 - 08:51 PM
Not a remote gearbox, but a remote gear change, which is what the gear change for a rod change gearbox is actually called, because it's actually 'remote' to the gearbox...
#15 danm
danm
  • 502 posts
Posted 15 January 2013 - 09:15 PM
Lots of conversions cropping up. Wonder if it will make the value of automatics go up? Quite neat little things really.
