1275 Automatic Conversion To Manual
#16
Posted 15 January 2013 - 10:00 PM
#17
Posted 04 February 2013 - 11:57 PM
Obviously the gearbox but, what bolt holes are different?
Does a manual flywheel housing bolt to an auto engine, or are the holes in a different?
Any build threads out there?
Any help would be much obliged!
#18
Posted 05 February 2013 - 12:03 AM
What exactly is different between the auto engines and manual engines?
Read this. Clicky
#19
Posted 05 February 2013 - 12:21 AM
Read this. Clicky
Thanks a million!:)
#20
Posted 05 February 2013 - 05:26 PM
3/8" spacer each side on the engine side of the engine mounts and it's nice and clean install.
Same drive shafts. ( pots )
You don't need to change out the whole pedal box.....just ad the clutch pedal to the existing pedal box after removing the spacer ( obvious when you look at it )
Staying with the auto subframe actually makes it easier to mount the engine etc....as there is now a little more space to get at the bolts.
#21
Posted 07 July 2013 - 03:33 PM
Sorry to be a pain guys but due to the auto engine in my 1982 998 A+ being completely knackered I have got hold of a 998 A+ manual engine and plan to swap them but, does anyone know the difference between the rover gear change remotes and the older ones? ive seen plenty of rover ones around 1993 for sale but not sure if they will fit mine or not?
#22
Posted 07 July 2013 - 03:50 PM
#23
Posted 07 July 2013 - 11:34 PM
The switch to rod change was 1974 or so.......so any rod change shifter should work for you.... I think the late 1275 rods may have been a bit shorter/longer(?)
Edited by Spitz, 08 July 2013 - 03:48 AM.
#24
Posted 08 July 2013 - 07:24 AM
#25
Posted 08 July 2013 - 08:48 AM
A selector from around 1993 or later would indeed have longer rods as the engine got moved 1/2" forward in the subframe. The cotton reel mounts won't last long using these selectors in an earlier car. You could re-drill the holes to move the selector back a bit as there is loads of clearance around it but then the standard gaiter will be stretched out of shape and the noise proofing pad under it won't fit.
