I've wanted a Mini since I was a boy and told myself I would never buy one unless it was local to me (driving distance), was drivable, LHD (sorry guys I promise I'm usually a purist), and RED. I finally found one meeting all these criteria and bought it.
NOW I have a problem. I've posted this on the minimania forums and was led here for more information.
http://www.minimania..._buys_dream_car
In Summary:
The car was billed as a 1974 Austin Mini with conversion - reported 1991 Rover 1.3 engine - LHD
Now I'm discovering that the engine is newer and an MPI
The previous owner knew very little about the car.
I drove it home about 200 miles and it lost power on the way as well as lost use of the tach. I limped home on what seemed to be limited power. The car will periodically (usually in a higher gear) backfire, lose power, and then upon a change in gear returns to its previous diminished power but remains very functional.
I have been told by my mechanic that the center two cylinders are not firing. A coil pack was recently replaced by the previous owner and the mechanic believes it is a faulty ECU because of the tach and non-functional cylinders. Many ideas have been weighed in and the belief on minimania is that a faulty ECU is less likely.
Tach function has been a problem for a while according to previous owner and the fuel gauge does not work either but he believes this are different problems since the fuel gauge is an old problem.
The oil temp gauge works.
Can anyone help me help him work this problem out?
Thanks so much to anyone who can provide any help! I've been shopping on this forum for a long time and dreaming about one day being an owner and am excited to have the car.
Some images:
