Us Question Regarding Recently Purchased Mpi With Only Two Cylinders Firing
#61
Posted 27 March 2013 - 01:17 AM
Relay next?
#62
Posted 13 June 2013 - 03:04 PM
The tach was an independent problem (wire again). Now I have all gauges working and 4 cylinders. I'm limping on a borrowed ECU/5as/fob at the moment.
Trying to decide now if I should just
1) buy a used ECU and use the ACR4 module to sync it with the alarm unit
-or-
2) try and find a used ecu, fob, 5as
-or-
3) send mine off and have it repaired and have the alarm/immobilizer removed
Does anyone have any experience with any of these options ESPECIALLY using the new scanner to sync a "strange" ECU to the alarm?
Suggestions?
Thanks again to all who helped me through this process. We have to add a stabilizer because of a broken bolt and once that's done I can finally hit the road on all 4 cylinders! It's currently in post from England!
Edited by rane, 13 June 2013 - 05:32 PM.
#63
Posted 13 June 2013 - 04:34 PM
I would personally keep the immob and alarm - has not really "security" as they are they offer a deterrent at the very least. Just get a new ECU in there, plenty of those around.
#64
Posted 13 June 2013 - 04:35 PM
Thanks. So you suggest just getting a lone ECU and trying the sync option with the ACR4. Any experience with this working?
#65
Posted 13 June 2013 - 11:15 PM
#66
Posted 13 June 2013 - 11:18 PM
Thanks for the reply. Important information. Can you elaborate at all on that? That certainly changes my direction. I was leery of buying a replacement ECU and that route not working.
#67
Posted 13 June 2013 - 11:27 PM
My point is that the ACR doesn't have functionality to reset anything to do with the alarm system, it works on the ECU alone.
If it was me I would have the ECU checked/repaired, a search in this area if the forum will throw up some Companies who specialise in this. Likewise if it was me I would keep the immobiliser function.
FS
#68
Posted 13 June 2013 - 11:29 PM
The SP G2 pod with iKeys when used with an ACR4 will indeed sync ECU/ alarms and add additional fobs.
Or at least the manual has specific instructions on how to do this. I have not yet performed this operation, but I am confident that the system does indeed perform this function. It better for the money that it cost.
Terry
#69
Posted 13 June 2013 - 11:40 PM
I too haven't tried this functionality as my G2 alas only had the iMAP subscription
FS
Edited by FlyingScot, 13 June 2013 - 11:42 PM.
#70
Posted 13 June 2013 - 11:49 PM
I was able to purchase a refurbished G2 with iKeys for an almost reasonable amount. Currently Ray(rane) has my older ACR4 with the Rover pod. If he needs the G2 pod, it is available to him to sort this out.
Terry
#71
Posted 13 June 2013 - 11:53 PM
tmsmini has been a godsend.
#72
Posted 14 June 2013 - 12:02 AM
#73
Posted 14 June 2013 - 12:04 AM
Searching like mad for one now that I know works and is for my MY. Found a source on ebay near your corner of the world but no reply as of yet.
#74
Posted 14 June 2013 - 06:33 PM
If anyone knows of an mpi ECU source or someone who might want to sell a working spare, please let me know. I'm not having good luck at the moment.
#75
Posted 15 June 2013 - 11:08 AM
Dont forget its the weekend here, and a lot of places/small buisnesses close at weekends...daft i know, but give them time to reply.
Have you thought of getting an after market ECU, then you cant map it to any future upgrades to the engine?
