Edited by minilover1, 18 January 2013 - 02:10 PM.
Help Removing My Engine With No Engine Lift
Posted 18 January 2013 - 02:05 PM
Posted 18 January 2013 - 02:08 PM
Posted 18 January 2013 - 02:09 PM
Posted 18 January 2013 - 02:11 PM
Posted 18 January 2013 - 02:18 PM
Posted 18 January 2013 - 02:33 PM
Posted 18 January 2013 - 03:04 PM
Posted 18 January 2013 - 05:06 PM
Posted 18 January 2013 - 05:21 PM
I find it easier to lift the engine, leaving the shell with 4 wheels & steering but, of course, you may want the subframe out of the way too. Lifting with a trolley jack is easiest, even if you add a rope to take in the slack as you lift, for safety.
Posted 18 January 2013 - 06:02 PM
Posted 18 January 2013 - 09:23 PM
that be dad ha ha i roped in four people because i could why struggal?
Posted 18 January 2013 - 09:25 PM
Edited by lucas1amps, 18 January 2013 - 09:26 PM.
Posted 18 January 2013 - 09:29 PM
I've lifted engines out of my car boot, (non-mini) but that's at a much better height
Posted 18 January 2013 - 09:40 PM
Posted 18 January 2013 - 09:59 PM
a pair of step ladders one side, workmate bench the other
slide a plank under the mini and lift either side when everything is disconnected, subframe bolts, dizzy off, heater pipes, etc.
lift mini up between a couple of you and ballance mini on the ladders and work bench, pull engine out.
Ta da !!
Graham
