Help Removing My Engine With No Engine Lift
22 replies to this topic
#16 pdaykin
pdaykin
  • 587 posts
Posted 19 January 2013 - 07:31 AM
Dont try and lift the engine out on your own - in my honest opinion it is a silly thing to suggest.
As the post above, if you only have one person and want to take the body off the suby its a case of a little at a time.
Raise it a bit. Put some wood under it. Raise it some more. etc. It is quite easy.
Dont forget to put some wood under the subby/gearbox before you start as it will tip.
Also, once the weight is off the suby the wheels tend to start going in opposite directions so it may be more akward to move than you think - make sure you have a bit of working space around you.
It is much, much easier with two people though !!!
Edited by pdaykin, 19 January 2013 - 07:35 AM.
#17 blacktulip
blacktulip
  • 6,224 posts
Posted 19 January 2013 - 11:16 AM
also dont forget to disconnect the battery cable from the subframe and soldenoid. i once did what your doing and forgot about that lol.
#18 valve bounce
valve bounce
  • 694 posts
Posted 19 January 2013 - 04:52 PM
i must say its a hell of alot easier to remove the engine separate to the sub frame. i have only once tried the all in one go job and simply never again. i have also lifted one out by myself like bmc says its not that bad, remove starter, alternator, rad, head etc to make it lighter i even removed the wok and flywheel. then trolley jack under the sump and jack it up as high as you can, my jack lifts up to 60cm so when its that high its not much to lift the engine onto the slam panel. then have a couple of blocks stacked up to just above bumper height and lift the engine from slam panel on blocks, job done.
or cut the slam panel out so you dont have to lift it so high, then just make a couple of brackets and bolt the slam panel back in
rob
#19 03jkirk
03jkirk
  • 465 posts
Posted 19 January 2013 - 05:19 PM
i think people that suggest lifting the engine on your own do need to be careful beacause every1 is a differant size and something easy for 1 person might seriously injure another, it can also do damage to your bak that might not become aparent for a long time so i would honestly steer clear of a single person engine lift unless you are fully confident that you have plently of liftin ability, if you have any doubt in your mind dont atempt it as you will end up injuring yourself
#20 valve bounce
valve bounce
  • 694 posts
Posted 19 January 2013 - 05:41 PM
yes sorry should have said that really.
#21 minimk4
minimk4
    Previously known as minilover1
  • 78 posts
  • Local Club: not yet joined
Posted 19 January 2013 - 08:05 PM
hahha cheers mate, we just removed the engine and we forgot then i come in to see this!!!!!
#22 minilee94
minilee94
  • 3,523 posts
Posted 19 January 2013 - 08:09 PM
If was me i would take engine out then subframe out easier but up to you i took my auto engine out in 3 and half hours me and a mate it took 2x 17 stone people a fat bit of rope a scaffold bar and a jack :) done out
#23 minimk4
minimk4
  • 78 posts
Posted 20 January 2013 - 09:41 AM
hey guys thanks for all your tips and advice picture available tonight on (my mk4 mini rebuild 1987 advantage) account minimk4
