Windscreen Blowers - Anyone Improved The Origional
Posted 20 January 2013 - 07:09 PM
Has anyone been able to improve / increase the fan speed that that blows through the windscreen blowers.
My 1977 Clubman is very poor (almost nothing), but the heater is quite strong (but new extremley hot).
Thanks,
Mark
Posted 20 January 2013 - 07:11 PM
Posted 20 January 2013 - 07:22 PM
I like the idea of these though!
http://www.cbsonline...st_Heater_DEMST
Posted 20 January 2013 - 07:26 PM
Hi,
Thanks,
Mark
I get quite a good stream of air through my vents on my 75 Clubbie. Is everything connected ok and not crimped up.
Posted 20 January 2013 - 07:42 PM
A few people swap the heater unit out completely for more efficient and smaller units. There's a few on here that work well... http://www.cbsonline...tilation,b.html
This actually looks like a good idea, can help along with the original heater fitted.
Posted 20 January 2013 - 07:58 PM
I believe that some of the works cars had a clear strip of plastic a couple of inches tall that sat along the bottom of the windscreen to help direct the air onto the screen but I could be wrong
Yes the works cars had a strip of perspex about 2 or 3 inches tall mounted on top of the dash rail to direct the heat higher up onto the screen. This was later superceded by the electrically heated screen.
Posted 20 January 2013 - 08:11 PM
Posted 20 January 2013 - 08:26 PM
Is the air still blowing out the front of the heater, when it's on the window setting ? If it is chances are that the control flap, has come off it's pivots and isn't controlling the airflow correctly. You'll need to strip the heater to correct this.........
When you select the screen option on the slider - heat still comes out of the heater!!! Maybe that is the problem.
Therefore I am now right in thinking that when you select the screen option, the in car heat blower should stop.
If so, looks like a heater strip down.
Thanks.
Posted 20 January 2013 - 08:58 PM
Posted 21 January 2013 - 09:34 AM
Posted 21 January 2013 - 12:42 PM
The small conventional heater does look very useful, but again I would like to see some pictures of one installed in a Mini, to see how it fits.
I see no reason why Mini owners should not benefit from modern technology to make the cars more comfortable in winter, as long as it still looks like and handles as well as, or better than a Mini of course. A secondary heater for the rear passengers and demisting of the quarterlights would not go amiss either.
Posted 22 January 2013 - 05:07 AM
http://www.t7design.co.uk/index.php?main_page=product_info&cPath=65&products_id=310
Posted 22 January 2013 - 08:00 AM
Posted 22 January 2013 - 08:21 AM
Minisport are reproducing this part aswell as others:
http://www.minisport...orks_Parts.html
Posted 22 January 2013 - 08:26 AM
Can't rate it highly enough
