Decal Application Woes
Posted 21 January 2013 - 09:18 PM
I was trying to apply it to the bonnet/wing half and half. I could not stop it from wrinkling or lie well at all!
The garage was pretty cold ( maybe 5 degrees), the vinyl is cheap and or I am a totally incapable of sticking on a sticker :)
Is the temp the issue or the cheap vinyl or both?
Posted 21 January 2013 - 09:28 PM
Posted 21 January 2013 - 09:31 PM
Edited by jaydee, 21 January 2013 - 09:31 PM.
Posted 21 January 2013 - 09:37 PM
I bought one of these to tint my windows, used with a hair dryer it works brilliantly.
Posted 21 January 2013 - 10:22 PM
Apply plenty of WATER to the door, slide the roundles over the water to the position you like, now with a card, remove the tiny bubbles moving them out the sticker. Dry out with an hairdrier. Job done.
Interesting ... Doesn't the water affect the adhesive?
Posted 21 January 2013 - 10:39 PM
Edited by 1275gtowner, 21 January 2013 - 10:40 PM.
Posted 22 January 2013 - 03:02 PM
Not at all, thats the proper way to stick them on, some are even using soapy water, but i prefer using plain water.
Some professional decals (which are usually a very thin vinyl) come with a transfer cover which helps when you're moving the decal around to avoid damage to the vinyl, but thats not the case!
Posted 22 January 2013 - 03:08 PM
Yeah i did some googling this morning and you are completely correct. Not that i didnt trust your opinion
I will give it a third attempt when the new vinyl arrives.........
