Anyone know where I can my seats repadded? granted they are 25yrs old but there's absolutely no padding in the back of the drivers seat and apparently the back seats like sitting on the bear metal shell underneath (wouldn't know as I've never had to use the backseat)
They're the standard park lane seats look a bit worse wear but with a bit of a clean should scrub up nicely just fancy travelling with a bit more comfort
Repadding Seats
a_woolhouse
, Jan 21 2013 09:42 PM
6 replies to this topic
Posted 21 January 2013 - 09:42 PM
Posted 21 January 2013 - 09:54 PM
Optimise automotive might do them, or minitrimmings in tean.
Posted 21 January 2013 - 10:00 PM
just go to a fabric supplier and buy some sheet foam of the appropriate (increased) thickness. If you're careful in taking the covers off and replacing them, you should be able to reupholster the backs easily.
Posted 22 January 2013 - 03:36 PM
I just redid mine, and found that the foam at the fabric store was actually really expensive. I save a ton by buying a cheap foam mattress topper at Walmart instead.
Posted 22 January 2013 - 03:41 PM
Good idea, I bought some memory foam once, I forgot where I put it though : )
Posted 22 January 2013 - 03:46 PM
unless you can buy foam cheap - i would be tempted to order from minspares pre cut and ready to go.
http://www.minispare.../seat foam.aspx
