Front Suspension, Little Help Needed?
Posted 22 January 2013 - 11:03 PM
Posted 22 January 2013 - 11:05 PM
But it is possible that the trumpet itself has broken.
Posted 22 January 2013 - 11:13 PM
Posted 22 January 2013 - 11:15 PM
With that much difference side to side the most likely culprit is the top arm knuckle joint cup. This is made from a hard plastic and over time it splits where the ball on the end of the trumpet sits into it.
You have to do the following:
Jack the car up and remove the wheel
Compress the rubber spring cone using the proper 'Tower Tool', also known as the Cone Spring Compressor.
Remove the rubber top arm down stop,
Pull out the aluminium trumpet with the ball on the end (it might be a bit difficult to remove the trumpet from the cone)..
Prise the old plastic cup out of the top arm, clean out the seat and fit a new cup.
Fit a new ball end into the trumpet
Put grease into the cup
Apply some copper grease around the top of the trumpet and re-install trumpet,
Jack up top arm to keep trumpet in the recess in the spring cone and release the compression tool slowly.
Re-fit the small rubber down stop under the top arm.
Posted 22 January 2013 - 11:21 PM
Posted 22 January 2013 - 11:28 PM
http://www.theminifo...-fitting-guide/
Posted 22 January 2013 - 11:36 PM
Just found this on minispares will it do? http://www.minispare...|Back to search
Or..Will I need this more expensive one??
http://www.minispare...07.aspx|Back to
Edited by RyanBebo, 22 January 2013 - 11:40 PM.
Posted 22 January 2013 - 11:43 PM
The cheaper version does not come with the earlier thread - Pre 1976.
More expensive version does.
Posted 22 January 2013 - 11:44 PM
SUSPENSION CONE COMPRESSOR TOOL METRIC THREAD
TOOL07
£15-75 +VAT
Well worth having the right tool.
You could fit Hi-Los at the same time which allows you to set the ride height at the same time.
Mini Spares Centre:
HILO
SUSPENSION ONE PAIR OF ADJUSTABLE TRUMPETS/HILOS
£37-50 +VAT
I've assumed a post-1976 car with metric cone thread.
Edited by Cooperman, 22 January 2013 - 11:45 PM.
Posted 22 January 2013 - 11:46 PM
Mines a 1996 mate, worth a purchase?How olds your car?
Yep mine is a 96, how reliable are hi/lo's?Mini Spares Centre:
TOOL07
£15-75 +VAT
Mini Spares Centre:
HILO
£37-50 +VAT
Posted 22 January 2013 - 11:48 PM
I think but i'm not sure you can in theory also raise it as Cooperman will say rally Mini's had raised suspension, so when it gets to the winter months and you don't want a snow plow, raise it up
I always raise my rally cars about 2 cm above standard rise height.
Edited by Cooperman, 22 January 2013 - 11:49 PM.
Posted 22 January 2013 - 11:52 PM
Are they really a worthwile purchase though, as I only drive my mini to work and back, and have the occasional journey to the maccies or kfc drive through
