Fast Engine Rebuild
14 replies to this topic
#1 Jamiestevens94
Jamiestevens94
  • 80 posts
  • Local Club: Snowdon Minis
Posted 28 January 2013 - 05:04 PM
I am hoping to be doing an engine rebuild soon and hopefully making it a fast road 1380cc one! I have been doing some research into it and was hoping to ask if any of you could give me some specifications and advice on stuff you have done to your engine such as what parts you used to achieve so I have more knowledge and can make a wise choice on what parts to use! Many thanks :)
#2 Old Bob
Old Bob
    TMF Menber Passed On R.I,P
  • 825 posts
Posted 28 January 2013 - 05:16 PM
Everything you need is here:
http://www.theminifo...-just-building/
Bob
#3 Jamiestevens94
Jamiestevens94
  • 80 posts
Posted 28 January 2013 - 05:25 PM
Bob
Cheers! :D
#4 Kam
Kam
    Straight to the Point
  • 4,140 posts
  • Local Club: 16vMini club
Posted 28 January 2013 - 06:15 PM
If your the kinda person who wants some footage to go along with it for reference then theres a few you tube vids but me personally I'd just get this DVD instead, probably will have some flaws but compared with you tube...
http://www.minifilms...iesbuilder.html
Good link Bob, nice work Andy :thumbsup:
#5 Jamiestevens94
Jamiestevens94
  • 80 posts
Posted 28 January 2013 - 07:24 PM
Okay thanks :). Should come in handy! :D
#6 Cooperman
  • 23,326 posts
Posted 28 January 2013 - 09:29 PM
1330 cc is better than 1380 because you don't have to offset bore and when the engine needs re-boring again it can be easily and cheaply sleeved back to 1275.
Much more cost-effective all round and you won't notice any difference in driving so long as the engine build is done thoroughly, carefully and well.
#7 jaydee
jaydee
  • 8,565 posts
Posted 28 January 2013 - 11:06 PM
A 1380 will cost you more to rebore and if something goes wrong the block is likely to be scrap or subjected to un-economical repair..
Much safer to go 1310 or even 1330
#8 Cooperman
  • 23,326 posts
Posted 28 January 2013 - 11:21 PM
I'm building an Innocenti Cooper 1300 engine for a friend at the moment. It was at +0.060", i.e. 1330 cc and the bores were badly worn. Re-sleeving including buying the sleeves, boring, pressing in the sleeves, honing the sleeves for the 1275 cc pistons and skimming the block to bring the new pistons flush with the deck cost just over £300 which I think is very reasonable. Now, had that been an offset-bored 1380 needing a re-bore it could be so expensive as to scrap the block - and they'll never make any more blocks.
Edited by Cooperman, 28 January 2013 - 11:22 PM.
#9 Kam
Kam
  • 4,140 posts
Posted 29 January 2013 - 02:13 AM
1380 just seems the 'peak point' people aim for
Me personally I'd rather have a 1293, 1310 at most
#10 Jamiestevens94
Jamiestevens94
  • 80 posts
Posted 29 January 2013 - 02:33 AM
Thanks for your replies! Must appreciated! :)
So doing a 1330 bore or something around that wont be much different to a 1380 in performance if everything else is the same?
#11 iMurray
iMurray
    Mild Cheddar
  • 1,396 posts
Posted 29 January 2013 - 07:55 AM
pretty much. plus i think 1330 sounds cooler. :shades: :shifty:
#12 Artful Dodger
Artful Dodger
    " I AM THE SPECIAL ONE"
  • 4,435 posts
Posted 29 January 2013 - 08:46 AM
1380 will be slightly better, but unless you need that little bit extra to win in the track it's pointless. You can make a 1330 go as fast as you could ever drive it! :D
#13 Jamiestevens94
Jamiestevens94
  • 80 posts
Posted 29 January 2013 - 01:29 PM
It won't be going on tracks to race unless i take it for a track day...rest lf the time it will be on roads :)
Thanks for the advice :)
#14 Cooperman
  • 23,326 posts
Posted 29 January 2013 - 06:08 PM
That is absolutely right.
It's the two 'comics' that go on about 1380 engines. I wonder what they will do when the price of blocks is so high that people can't afford them and the 1380 needs re-building.
1275 blocks are already selling for twice what they were a few years ago.
1380 is fine if you want to knock a couple of tenths of a second off a lap time, but for a road car there is no point.
#15 Jamiestevens94
Jamiestevens94
  • 80 posts
Posted 29 January 2013 - 09:25 PM
Okay cheers for the info :D
