Alloy Suspension Parts
52 replies to this topic
#1 Neilson
Neilson
  • 183 posts
Posted 29 January 2013 - 12:40 PM
I’m considering using alloy suspension parts (radius arms, hubs, upper arms etc) on my project and was wondering what peoples thoughts are. Are they as strong as the original steel versions as they seem to be the same dimensions as the originals (ie no addition material).
The mini will be for road use.
#2 Wil_h
Wil_h
  • 3,244 posts
Posted 29 January 2013 - 12:52 PM
The KAD radius arms are great and the alloy rear hubs are also nice, both suitable for a road car.
Personally I'd keep the front all steel though, especially the hubs.
#3 Neilson
Neilson
  • 183 posts
Posted 29 January 2013 - 03:25 PM
Thanks Wil
Can I ask why? is it for the rigidity or strength?
#4 rally515
rally515
  • 3,848 posts
Posted 29 January 2013 - 03:42 PM
I pearsonaly wouldnt use the top arms in alloy that your on about (although i've never seen aliminium top arm i wouldnt think they could be that much bigger for strenth as they do take a pounding even on a road car.
#5 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 29 January 2013 - 05:00 PM
On the outside maybe, the standard radius arms are hollow. The cast ally ones are presumably thicker walled than standard. Specialist Components stopped making the standard suspension version of their radius arms because the knuckle cups were tearing off, they couldn't get enough aluminium around that area to make them strong enough. Gives you some idea of what you are up against. Where have you found ally top and bottom arms?
#6 Neilson
Neilson
  • 183 posts
Posted 29 January 2013 - 05:14 PM
I haven't but I work at an engineering company so was thinking of making some. I didn't realise the original radius arms were hollow. That explains alot. Alloy top arms definately won't be strong enough then as I'm sure the originals are solid.
#7 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 29 January 2013 - 05:16 PM
Force Racing do some rather nice fabricated titanium top arms, not sure how road legal / insurance friendly or not they might be though.
#8 freaker
freaker
  • 1,378 posts
  • Local Club: mini fun club belguim
Posted 29 January 2013 - 05:31 PM
but still why on a road car ?
you won`t gain anything out of it...
#9 Cooperman
  • 23,324 posts
Posted 29 January 2013 - 05:42 PM
That's what I was thinking. Lighter suspension parts are to reduce the unsprung weight for a racing car, not for a road car. If you drive in a manner where the reduction in unsprung weight will increase performance on the road you'll soon be travelling by bus ;D
#10 tiger99
tiger99
  • 8,584 posts
Posted 29 January 2013 - 05:59 PM
The big problem with using alloy parts on a road car is fatigue, as allow does not have a fatigue threshold, unlike steel, and will always fail after a certain number of load cycles. Suspension parts designed for competition use, which generally means limited mileage, are dangerous on the road, as the fatigue life will be used up well within the lifespan of a normal road car. Badly fitted ball joints apart, suspension fractures on a normal Mini are almost unheard of, however if you use alloy parts, expect them to break. The big problem is that because the loads applied to a road car are very variable, you can't predict what the safe life will be, for example kerbing might use up half the fatigue life in an instant. Unless the designers clearly state their design load assumptions and predicted life, I would be very wary indeed.
A radius arm, for instance, which is alloy will probably need to be as heavy as a steel one to get 100k miles of normal road use. Top arms are a complete no-no because of the loading, because they would have to be impossibly thick.
For safety's sake you should stick to steel. The limiting factor on the life is corrosion, as they are designed to be stressed significantly below the fatigue threshold, and so are safe for unlimited mileage.
An alloy part of the same dimensions as the original steel part is unsafe, as it will be lacking in both fatigue and static strength.
#11 mini-luke
mini-luke
    Postman Pat
  • 2,362 posts
Posted 29 January 2013 - 06:09 PM
Does this not make alloy wheels dangerous?
#12 Neilson
Neilson
  • 183 posts
Posted 29 January 2013 - 07:31 PM
Thanks guys, I appreciate all your points. I'll have a re-think regarding the suspension parts.
What about the hubs?
#13 03jkirk
03jkirk
  • 465 posts
Posted 29 January 2013 - 07:46 PM
alloy wheels are mostly safe as they are very thick, but some cheaply made aftermarket alloys can be dangorus is put under hard load, original porche 911 alloy split rims are extremely rare nowday because they had a massive problem with cracking as they did not have enough material to make them strong enough, also as was said to be as strong as steel they have to be as much weight of alloy to cope and ally wheels are generally heavier than equivilant steel wheels due to the extra material
Edited by 03jkirk, 29 January 2013 - 07:48 PM.
#14 rally515
rally515
  • 3,848 posts
Posted 29 January 2013 - 07:57 PM
The pinned thread on "weights" confirms this.
Ironic really but true,if you want to go light get rid of your alloys& get some steelys >_< .
Although if you can find them magnesium (think i spelt that right) are lighter than both.
#15 tiger99
tiger99
  • 8,584 posts
Posted 30 January 2013 - 07:55 AM
Yes, lightweight alloy wheels are very dangerous, and long life alloy wheels are heavy. My current daily driver is the first car I have ever had with alloy wheels, and they are by far the heaviest wheels I have ever had. Even so, the alloy wheels have a limited life, and if fitted as standard to a production car that has probably been designed to be at least half a million miles, but if you take arbitrary wheels, not approved by the car manufacturer, you have no way whatsoever of knowing for how long they will be safe, as the wheel manufacturer has no way of knowing the load conditions for the vehicle.
Alloy wheels on standard production cars are a despicable cost-inflating gimmick, driven by marketing idiots with no engineering knowledge, knowing that a largely ignorant general public will be easily conned into buying them. They provide no improvement whatsoever, add weight, and really do degrade safety. Unfortunately it is often impossible to avoid them.
It follows that I would never, ever buy a second hand alloy. There is no possible way of knowing how near it is to failure. The vehicle it came from may have been regularly overloaded, and wheel fatigue life varies very strongly with vehicle weight, as well as quality of the road surface and how hard it is driven.
