Help Please 165/70/10 Tyres Not Going On 6 Inch Rims
26 replies to this topic
#1 mex
mex
  • 42 posts
Posted 30 January 2013 - 08:45 PM
hi
i have a set of 10 inch mws 6 inch wide wheels they look like deep dish revolutions
they have worn yokos on, two needed replacing as on limit so i bought some falkens then took to quick fit to fit but quick fit ruined one by splitting the sidewall, they said the tyre was not wide enough
i have been to all the loal tyre fitters who tried to put them on an the machine has actually stopped as it was too tight
i bought some camacs and was told they came off 6 inch rim but same again too tight
looking at the rim the wheel wells look the same size, not sure if this could be the problem
maybe yokos are softer so will stretch more
have enclosed pic of rim
any info appreciated
cheers
Attached File  DSCF1185.JPG   36.77K   12 downloads
Attached File  DSCF1186.JPG   73.72K   3 downloads
Attached File  DSCF1184.JPG   32.69K   10 downloads
#2 Willthewelder
Willthewelder
  • Validating
  • 161 posts
  • Local Club: Colchester Mini Club
Posted 30 January 2013 - 08:47 PM
They aren't splitrims are they? Could be they were meant to have crossplys not steel belted radials?
#3 Hegnirst
Hegnirst
  • 3,496 posts
  • Local Club: Hilltop Minis
Posted 30 January 2013 - 08:48 PM
there full of rubbish mate, if they cant do it, dont go there, they dont know hat they doing. Ask on here if someone knows where the place is best to go near you or ask your local mini spares guy :)
theres always a local spares guy :P
#4 mex
mex
  • 42 posts
how can i tell if split rims
they had yokos on which were 165/70/10 and they were ok
cheers
#5 Shane.spears.91
Shane.spears.91
  • Just Joined
  • 240 posts
  • Local Club: Mini Hawks
Posted 30 January 2013 - 08:49 PM
i know my machine wouldn't cope when i stuck those tyres on my 10x7s. i had to use the tyre leavers while having the wheel clamped down on the machine. there on there now!
#6 Artful Dodger
Artful Dodger
    " I AM THE SPECIAL ONE"
  • 4,435 posts
I THINK that there is a big problem with these wheels. The issue is that tyres will not go on them!! I think they are returnable due I the major flaw!!
Don't take any action on this until someone else confirms it. I may be wrong :P
#7 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,146 posts
  • Name: Sean
Theres a very big old thread on this very subject, I'll have a look and see if I can find it.
As I recall the wheel design is wrong which makes it nearly impossible to get the tyres on.
#8 mex
mex
  • 42 posts
Posted 30 January 2013 - 08:51 PM
i know when he took the old yoko off he bent 2 tyre levers and it took over an hour to get it off, i know as i was watching him sweat and swear at it
he said the rims are not right
sonick4 the tyre wont even go on the rim as too tight
the quick fit muppet got the other one on the rim then used the bead blaster to seal it when he inflated it it had a massive bleb on it where he caught it on the sidewall
Edited by mex, 30 January 2013 - 08:55 PM.
#9 Shifty
Shifty
  • 13,146 posts
  • Name: Sean
Posted 30 January 2013 - 08:52 PM
http://www.theminifo...mws-6x10-revos/
#10 Artful Dodger
Artful Dodger
  • 4,435 posts
Posted 30 January 2013 - 08:54 PM
If you look at the wheel the tyre well is in the middle. Other wheels have offset wheel wells to get the tyre on. With a deep dog wheel the well is either right near the dish or offset the othe war around, so you put the tyre on backwards.
#11 Shane.spears.91
Shane.spears.91
  • Just Joined
  • 240 posts
Posted 30 January 2013 - 08:56 PM
bent two levers? what where they, Chocolate?
#12 mex
mex
  • 42 posts
Posted 30 January 2013 - 08:57 PM
thats right artful dodger
normal rims are easy i was told they maybe rims for racing as the tyre wont come off if punctured
not sure if right
thanks shifty reading it now
#13 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 30 January 2013 - 08:59 PM
Tell em to put the wheel on the clamp with the outer rim down.
#14 Artful Dodger
Artful Dodger
  • 4,435 posts
Posted 30 January 2013 - 09:00 PM
Nope. Racing wheels are pretty much the same as road wheels. Racing wheels that are for autograss etc use bead lockers. Nothing to do with the tyre well.
Save yourself the hassle and get another set of rims.
General question: will midland wheels accept these as returns due to incorrectness! :D
#15 Artful Dodger
Artful Dodger
  • 4,435 posts
Posted 30 January 2013 - 09:01 PM
Wouldn't make any difference the wheel well is in the middle! The wheel well is paramount to fitting tyres:P
