Whirring And Grinding Noise After Bang On Motorway - Help!
#16
Posted 04 February 2013 - 11:46 AM
Jack up one wheel with the other on the ground, third gear on, accelerate for a second, you'll be able to identify the side to strip down and inspect.
#17
Posted 04 February 2013 - 02:04 PM
So, the diff is shagged I'm guessing?
#18
Posted 04 February 2013 - 02:41 PM
#19
Posted 04 February 2013 - 03:07 PM
Since the casing had some damage, I got a new gearbox from Guess-works.
#20
Posted 04 February 2013 - 03:51 PM
This shall be my plan of action unless anyone thinks there's anything else worth checking first?
The clutch is properly knackered as well, so it would give me an excuse to change that over whilst I've got the engine out.
#21
Posted 04 February 2013 - 06:41 PM
#22
Posted 09 February 2013 - 06:29 PM
#23
Posted 09 February 2013 - 06:32 PM
#24
Posted 09 February 2013 - 08:19 PM
#25
Posted 09 February 2013 - 08:24 PM
I'm just swapping boxes for now a decent second hand one, a proper strip/re-build will happen in the summer.
#26
Posted 09 February 2013 - 08:27 PM
#27
Posted 09 February 2013 - 08:32 PM
ooohh, a white italian job next to yours..................
Yeah it reminded me of you mate!
#28
Posted 09 February 2013 - 08:39 PM
Yeah it reminded me of you mate!It only has one skinny white minilite on it, the other three wheels are satin black 13x7 superlites, hence the big arches! Original bodywork apart from that though, and the interior is beautiful and original, and obviously from it's stance you can see the engine has been taken out.
is it in for work on the engine then?
#29
Posted 09 February 2013 - 08:43 PM
I'm not sure to be honest, I haven't asked! I don't know if the garage owner has bought it for parts/restoration or whether it's a customers car... I'll try and remember to find out for you on Monday why it's there. Not interested in parts off it are you?
#30
Posted 09 February 2013 - 11:19 PM
but now that knocking noise can be done on command. Every time you accelerate and every time you get off the power it knocks, from the drivers side I think. I know you'd all suggest engine steadies for this but the engine is completely solid, the bushes are fine and you can rock the whole car by grabbing the engine and it doesn't budge.
I had the same problem, after many a week scratching my head I replaced the few months old rubber bushes on the engine steady and now magically the knocking is fixed. There was virtually no movement in the engine, and I was trying to pinpoint the issue, so I disconnected the engine steady and rocked by hand and there was no knocking. So I put it back together (with the old bushes) and i still got knocking, so replaced the bushes and now all is well. The rubbers I replaced were one piece ones I got with my engine steady. The must have only done a few hundred miles at the most before starting to knock.
