Over Filled With Oil
27 replies to this topic
#1 herdy
herdy
  • 377 posts
  • Local Club: Notts about minis
Posted 04 February 2013 - 09:03 PM
I noticed i had an oil leak from my rocker cover because the gasket wasn't sitting right. I sorted that out and checked my oil level, it was low so I topped it up, but like a t*** I've put far too much in. Has any body got any idea how to get some of it out without draining it all out. Thought about siphoning some out via the dip stick. what are your thoughts on this? or do you have a better idea?
Thanks a lot, Ben.
#2 jaydee
jaydee
  • 8,565 posts
Posted 04 February 2013 - 09:05 PM
The engine will eat it very soon..how much overfilled?
#3 Fast Ivan
Fast Ivan
  • 2,910 posts
Posted 04 February 2013 - 09:07 PM
just open the sump plug carefully without removing it completly and drain what you need.
#4 herdy
herdy
  • 377 posts
Posted 04 February 2013 - 09:10 PM
It's well past the Max point.
i meant to mention it's a '92 mayfair 1275.
#5 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 04 February 2013 - 09:11 PM
use a oil change pump straight down the dip stick hole.
#6 F1L8EY
F1L8EY
  • 600 posts
Posted 04 February 2013 - 09:15 PM
i did this once in my mayfair... i was pulled over on route to a mini club meet by an enthusiastic police officer who mistook me for a white arrow :shades:
Edited by F1L8EY, 04 February 2013 - 09:15 PM.
#7 herdy
herdy
  • 377 posts
Posted 04 February 2013 - 09:16 PM
I'll have to have a scout about in the garage for one, can't think that i've got one.
#8 jaydee
jaydee
  • 8,565 posts
Posted 04 February 2013 - 09:17 PM
Place a container under the sump, undo the sump plug a bit as Rob Mac suggested and drain out about a pint of oil. Now fill up to MAX mark.
#9 herdy
herdy
  • 377 posts
Posted 04 February 2013 - 09:19 PM
I've not started it up yet but it'll be smoking more than bob marley :P
#10 OfMini&Men
OfMini&Men
  • 284 posts
Posted 04 February 2013 - 09:21 PM
how much over? if its a like a few mm ir be fine :) but most of it properly leak out anyways
#11 herdy
herdy
  • 377 posts
Posted 04 February 2013 - 09:24 PM
Gonna be the first thing I try tomorrow. Thanks guys, I'll let you all know how it goes.
Damn my impatience.
#12 firstforward
firstforward
  • 824 posts
Posted 04 February 2013 - 09:51 PM
Unscrew the oil filter, remove the HT leads and turn it over whilst it pumps out how much you want to remove.
#13 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 04 February 2013 - 09:55 PM
That rings bells as a bad idea to me. One it will be messy and two, running/cranking an engine with part of the oil system missing is not gunna be good for flow or pressure.
Remove the sump plug to drain, its the easiest way.
#14 mini13
mini13
  • 3,811 posts
Posted 04 February 2013 - 09:57 PM
you really have to go some to overfill a mini engine because of the gearbox,
at the max mark the oil is just over half way up the gears, to cause issues you'd need another 2" or so of oil in there which is probably getting on for a gallon.
#15 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 04 February 2013 - 10:02 PM
out of the dip stick hole is fine
it's the only way to get the oil out a lot of boat engines
