What Style Rear Number Plate Lights Are There?
#16
Posted 06 February 2013 - 10:24 PM
#17
Posted 06 February 2013 - 10:46 PM
#18
Posted 07 February 2013 - 07:07 AM
http://www.minispare...px|Back to shop
I'd fit a MK1/2 style light under the plate, you are going to have to drill some holes though whatever you fit, cover the paint with masking tape to mark it all out, this will help the drill not to slip
#19
Posted 08 February 2013 - 09:04 PM
#20
Posted 08 February 2013 - 09:13 PM
#21
Posted 09 February 2013 - 06:54 AM
#22
Posted 09 February 2013 - 08:36 AM
Why not fit a MK3 badge of you choice (or personalised) In the badge holes, then you could either make up a plate to hold the lamp directly to the number plate or get the original backing and use extended bolts with spacers behind to fix it all on to the boot lid using the holes you already have for the number plate, then you will only need one extra small hole with the correct grommet (suitably rust proofed) for the lamp wiring. If you put that lamp above the plate it will just look wrong IMO
hi thanks for your reply. i am trying to avoid badges really i should of had the holes coverd up before painting would of been alot better but didnt think about the holes there a few by the number plate two that i only just coverd with the numberplate. ile have to try two customise this one and if it doesnt look two good ile stick with the original one. ile get some pictures tonight of a template i have made thanks tomWhy not fit a MK3 badge of you choice (or personalised) In the badge holes, then you could either make up a plate to hold the lamp directly to the number plate or get the original backing and use extended bolts with spacers behind to fix it all on to the boot lid using the holes you already have for the number plate, then you will only need one extra small hole with the correct grommet (suitably rust proofed) for the lamp wiring. If you put that lamp above the plate it will just look wrong IMO
