Revs Drop With Lights On?
19 replies to this topic
#16 Moggyton
Moggyton
  • 1,152 posts
  • Local Club: Stone mini club
Posted 21 February 2013 - 07:15 AM
As they say 'oop north', "There's nowt for nowt".
When you turn the lights on you are using the engine to generate the power for all the lights, so the load on the alternator and thus on the fanbelt increases. This takes some power from the engine which then slows slightly. 200 rpm is quite a big drop, but not totally unusual.
It shows how much extra fuel is being used when driving with the lights on.
i dont think how the performance changes in mine is normal though :/
#17 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 21 February 2013 - 01:47 PM
Its the juddery bit that makes me think this could be a slight misfire?
#18 Moggyton
Moggyton
  • 1,152 posts
Posted 21 February 2013 - 09:51 PM
But it would still be fine with the lights off?
#19 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 21 February 2013 - 10:05 PM
If its voltage related to the ignition yes, you'll never find it unless its tested with a meter though were just guessing. It could be something as simple as a weak coil and the voltage drop could cause a slight miss.
Pity your not in Cornwall I'd do a full electrical check for you, its the only way to find it without throwing loads of bits at it, unless you strike lucky
#20 Moggyton
Moggyton
  • 1,152 posts
Posted 22 February 2013 - 03:58 PM
oh right, thanks
