Hello,
this is my first attempt at fitting a radio so be gentle!!
Looking on here i found several times that you can get a switched live and a permenant live straight from the fuses, the problem i have is the second fuse down (carn't remember if this is switched or permennt) has a wire coming of both terminals.
Is it safe to piggy back on of these to run a wire into the inside of car and which live wants an inline fuse??
Thanks for your help
Help With Radio Install
venkman
, Feb 12 2013 06:03 PM
4 replies to this topic
Posted 12 February 2013 - 06:03 PM
Posted 12 February 2013 - 06:18 PM
i had never done anything like this before but i followed this guide and everything worked (and still works) fine
http://www.theminifo...atch-in-a-mini/
Posted 12 February 2013 - 07:31 PM
It's the permenant live that has the fuse
Posted 13 February 2013 - 05:23 PM
Remylebleu
did you run a wire right up from starter solenoid up into the cabin in a direct connection?
What size wire did you use if you can remember?
