Please Tell Me Someone Has Fitted A Mini Sport Quick Shift Pleaaassseeee
Posted 13 February 2013 - 03:41 PM
Posted 13 February 2013 - 04:02 PM
I have one on mine (non kad) and I hate it if you were close to me I'd swap and fit it for you, mine is very close movement the wife cant get on with it
Edited by KernowCooper, 13 February 2013 - 04:03 PM.
Posted 13 February 2013 - 04:13 PM
Those two pins look quite hard to get out 1 goes through and you can see it inside where the lever ball sits and one don't did you punch them out or mole grips would it be better and easier to drop the linkage box as I have no engine in it at the moment anyway cheers again
Posted 13 February 2013 - 10:25 PM
As they say, you can cut a bit off, but you can't cut a bit on...
Posted 13 February 2013 - 10:54 PM
Mine's Kad and it required the pins to be removed as well.From memory on some non kad quick shifts require the removal of the 2 pressed in location pins in the std lower gearchange
I first used a pair of big jaw pliers to push in the two pins so they are set in flush towards the center of the housing. I then stuck a lot of paper towels into the housing.
With the pins sitting flush, I was able to put the quickshift housing on. Then I screwed the screws in through the quickshift housing to where the stuck pins are. It pushed the pins in and they landed on the paper towels inside and can be collected.
Posted 14 February 2013 - 01:09 AM
Posted 14 February 2013 - 07:20 AM
This is my first Mini, and I've never driven one with the stock shifter, so I can't comment on the difference. But so far (only a couple of test drives) I've found reverse very difficult to engage. I'm not sure this is related to the quick-shift, but I seem to recall that reverse was a lot easier with the stock shifter (which was worn out and sloppy).
And I bought the quick-shift because it was cheaper than the stock shifter...
Posted 14 February 2013 - 08:22 AM
Posted 14 February 2013 - 08:23 AM
Posted 14 February 2013 - 06:11 PM
Posted 14 February 2013 - 06:18 PM
Posted 06 April 2013 - 11:36 AM
Posted 06 April 2013 - 11:59 AM
Posted 06 April 2013 - 12:06 PM
Posted 06 April 2013 - 12:14 PM
