Throttle Cable Help!
25 replies to this topic
#1 lewBlew
lewBlew
    Previously known as theboybradley.
  • 1,238 posts
Posted 16 February 2013 - 03:14 PM
I've just had a pig of a job replacing the accelerator cable in my Mayfair - sorting out both ends of the cable was fine but the bit where the outer meets the engine bay side of the bulkhead has really confused me. When I took the old cable out it needed a real tug to budge, but the new one is kind of loose. It clicks in to the metal grommet-type protusion on the bulkhead but doesn't stay in there firmly and if I use the pedal a bit it comes loose. Is it meant to fix in here or does it not matter?
Help?!
#2 MRA
MRA
  • 7,607 posts
Posted 16 February 2013 - 03:30 PM
Did the old outer cable have a metal ferrule on the end as per your new one ?? if not then you need to remove it from your bulkhead, I always apply a small smear of copper grease to the ferrule to ensure it doesn't stick again
#3 lewBlew
lewBlew
  • 1,238 posts
Posted 16 February 2013 - 03:34 PM
Yes it looks like this:
Except it has silver ends, not brass coloured.
#4 MRA
MRA
  • 7,607 posts
Posted 16 February 2013 - 03:43 PM
Is that the old one or the new one ?
#5 lewBlew
lewBlew
  • 1,238 posts
Posted 16 February 2013 - 03:50 PM
New one has silver ends, old one bronze. Otherwise they are identical
#6 MRA
MRA
  • 7,607 posts
Posted 16 February 2013 - 03:53 PM
Ok does the bulhead have what looks like a ferrule sticking out of it ?
#7 lewBlew
lewBlew
  • 1,238 posts
Posted 16 February 2013 - 03:58 PM
Yes well a hollow nut like thing sticking out which the outer cable end goes into.
#8 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 16 February 2013 - 04:01 PM
Does the return spring pressure not keep the outer cable in the furrel while working the throttle pedal? is the cable run smooth and the throttle pedal feel smooth in operation with the new cable?
The cable inner is not to long where it goes through the nipple on the carb and the long end catching on the heat shield/linkage? as this will cause the outer to come out the bulkhead nipple,
Edited by KernowCooper, 16 February 2013 - 04:13 PM.
#9 MRA
MRA
  • 7,607 posts
Posted 16 February 2013 - 04:20 PM
The cable ferrule should be fixed to the end of the cable, it should not be loose.
#10 lewBlew
lewBlew
  • 1,238 posts
Posted 16 February 2013 - 04:54 PM
It is fixed to the end of the cable! It's not fixed to the bulk head, it just sits in the hole and is easily pulled out. That's what i want to know whether that's normal or not.
Just been for a drive and it's very revvy, nice! Smooth etc
#11 MRA
MRA
  • 7,607 posts
Posted 16 February 2013 - 04:56 PM
Yes pretty mush, its not a tight fit, as stated above the spring and pedal hold it in tension that keeps it all together, also the adjustment should not allow it to move far enough to fall out
#12 lewBlew
lewBlew
  • 1,238 posts
Posted 16 February 2013 - 05:21 PM
I think I'm ok then. It drives better anyway, I can blip the throttle and I shoot off, unlike before. It's quite fun/dangerous.
I guess the pressure from the spring keeps it in place, at least for now. Thanks for your help both.
#13 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 16 February 2013 - 05:59 PM
I was calling the furel the bit in the bulkhead the outer cable goes into
#14 MRA
MRA
  • 7,607 posts
Posted 16 February 2013 - 06:11 PM
That is not the ferrule, that could be called a boss but it is not a ferrule
http://en.wikipedia.org/wiki/Ferrule
Please also note that the correct spelling is Ferrule.
#15 lewBlew
lewBlew
  • 1,238 posts
Posted 16 February 2013 - 06:31 PM
I've never heard of the word ferrule before today, but anyway I think the 'ferrule' is being pushed against the 'grommet' by the spring so my question is answered ;-)
