Can someone help.... I have just bought new minilite wheels ... Whilst changing the first one over from old standard ones ... SNAP .... One of the wheel bolts snapped not happy .... Can these easily be replaced ? Do I need to strip everything down ? Or do I need to take to garage ... Any info would be appreciated
This will be my first job in the morning
Thanks in advance
Snapped Wheel Nut
Smee2012
, Feb 16 2013 09:18 PM
4 replies to this topic
Posted 16 February 2013 - 09:18 PM
Posted 16 February 2013 - 09:39 PM
Which one is it? and are we talking front discs or rear drums ?they are pressed into the flange and splined not sure there is enough room to put a stud in without taking the flanges off.
I followed the link in from the right and see now its in the spi/mpi section so std is discs front and drums rear. do you have a replacement stud? if so knock it through and try one
Edited by KernowCooper, 16 February 2013 - 09:44 PM.
Posted 16 February 2013 - 10:15 PM
Front disc ... I do not have a replacement for it as every where was closed when it happened ... I am hoping that I can just hammer it out ??? ... And hopefully can get one from halfords ? As they are the closest ... That's if it straight forward ... Just didn't want to start hitting it with a hammer and ******* it up
Posted 17 February 2013 - 11:24 AM
I'll be suprised if halfruads have them in stock, or any motor factors on the shelf.
order one from mini spares etc, best order 2 or 3 as back ups too eh
Posted 17 February 2013 - 12:06 PM
As said most likely need to get it from a proper mini suppliers or at least order in at a proper motorfactors... Also i would seriously consider swapping them all as if one stud has snapped the others wont be far be much different.
