Hi all,
Now I have the engine running on the temporary loom what is the easiest way of checking oil is being pumped round the engine properly?
I haven't got an oil pressure gauge that is plumbed in so don't even know if the pressure is ok. Don't want to run it much without checking this out.
Thanks,
Graham
Checking Oil Movement?
grahama
, Feb 19 2013 02:52 PM
6 replies to this topic
Posted 19 February 2013 - 02:52 PM
Posted 19 February 2013 - 03:34 PM
Just get yourself an oil pressure gauge, it can be a life saver.
Posted 19 February 2013 - 04:05 PM
Only basic check is whip up the rocker cover and look for the signs of oil, but that wont confirm oil pressure only safe way is a pressure gauge as said by BRG above mate
Posted 19 February 2013 - 05:15 PM
Or you could use the standard oil pressure switch, 12v bulb pick up a 12v feed from your loom and the other side of the bulb to the lucar on the standard oli pressure switch, making sure you have a earth and it will work the same as a standard car fitment.
Depending if the switch is the std 5psi or the competition 22psi you will know it at least has one of the pressures.
Posted 19 February 2013 - 05:27 PM
Have ordered a gauge pipe to test properly but would like to quick test as u say. Not sure of your wiring tho.
Is it 12v to one side, other side of bulb to spade on oil switch and earth block as usual, light will go out with pressure??
Posted 19 February 2013 - 05:34 PM
I assume you at least have a low pressure warning light wired in?! I'd never run an engine for more than a couple of seconds without one, even then that would be extenuating circumstances.
Posted 19 February 2013 - 05:50 PM
Not at present, oops, have only run it for short bursts of a few seconds so far. This is the point of my question so I don't damage anything
