Worm & Pinion Ratio
Best Answer Pitcrew6464 , 20 February 2013 - 06:19 PM
guessworks website is good for that ;) Go to the full post
5 replies to this topic
#1 Elliskwleisk
Elliskwleisk
  • 250 posts
Posted 20 February 2013 - 06:04 PM
How can I find out what my worm and pinion ratio is?
#2 Pitcrew6464
Pitcrew6464
  • 1,673 posts
Posted 20 February 2013 - 06:19 PM   Best Answer
#3 DannyTip
DannyTip
  • 1,020 posts
  • Local Club: A Series Magpies
Posted 20 February 2013 - 06:34 PM
This is your 3rd topic asking the same question.
#4 Minidarren83
Minidarren83
  • 1,207 posts
Posted 20 February 2013 - 06:52 PM
Take it out and count the teeth unless it is standard then gw website should tell you standard
#5 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 20 February 2013 - 07:08 PM
1984
998cc
13x7 wheels
3.44 final drive
What speedo is correct for my car?
Quote take from your other post...
If the speedo is original to your 1984 mini then it'll either be a 90mph centre speedo which runs 1280 tpm or a 90mph smiths speedo ( dual clock ) which is in front of the drive, this will have a 1216 tpm...
so If you have 13" wheels and a 3.4 final drive, your drop ratio is 1:1 as standard, also the drop gear ratio does not affect the speedo drive ratio, just the RPM.
You can now use the previously advertised calculator ( http://www.guess-wor.../Tech/ratio.htm ) to work out the correct speedo drives, and one can only assume that at the moment you have the wrong ones installed.
Edited by Guess-Works.com, 20 February 2013 - 07:09 PM.
#6 Elliskwleisk
Elliskwleisk
  • 250 posts
Posted 20 February 2013 - 07:32 PM
The other posts main topics were different and I've made a seperate one for this specific topic because I haven't had an answer that has suited my circumstances.
